Sharp LC-43CFE6131K remote buttons switched
  • caveman11
    • Oct 2013
    • 22
    • uk
    HI guys,
    Just replaced the all in one main board on this LC-43CFE6131K and all is working well...
    Except 3 buttons on the remote are interchanged..the fav, source and back buttons.
    I cannot find the service menu access codes to possibly change remote settings if applicable...tried a few that I could find.
    Main board numbers are correct.
    Anyone have a solution to this?
    Many thanks
  • caveman11
    • Oct 2013
    • 22
    • uk
    Re: Sharp LC-43CFE6131K remote buttons switched
    p.s. it is the original remote
    • ducky29
      • Dec 2015
      • 370
      • Europe
      Did you flash the correct firmware after replacing the mainboard, or it came from the same model?
      • caveman11
        • Oct 2013
        • 22
        • uk
        exact same model
        This model also has a pairing procedure before 1st use...tried that.
        • advant
          by advant
          02-03-2020, 12:25 AM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • m4a2t0t
          Sharp LC-60LE550U Mainboard F905FM06 DUNTKF905WE06TV Main board keeps dying
          by m4a2t0t
          What would cause a main board to die when you disconnect AC power to the TV?
          This is the second board that it has happened with. All I am doing is disconnecting the power cord from the wall and plugging it back in.
          I replaced the main board because I was not getting a signal on PS_ON when pressing the power button. The PSU was/is still sending its 5v standby signal
          03-27-2023, 04:05 PM
