Philips 42PFL5609S/98 Intermittent screen off
  • KCLim168
    • Sep 2018
    • 5
    • Malaysia
    I have above TV and it has the intermittent problem of screen going off totally after about 1 hour of watching but the sound is still on. I then switched off the power and restart again but still get blank screen. I am still testing the pattern for which this happens and will update later as I find out more facts.
    I have searched this forum for a similar TV (42PFL5609/98) but slightly different symptoms. However couldn't really see the status of it.
    I have done a visual inspection on the boards inside for possible causes like bad cap, burn marks but everything looks fine visually.
    I would appreciate friends here to further guide me to the likely cause of this.
    Many thanks.
    Re: Philips 42PFL5609S/98 Intermittent screen off
    I had this fault before on an old Philips 37" plasma using a Hitachi panel. Yours seems a bit too new for that and may use Samsung panel. Check Vs and Va voltage when set shuts off, if this goes away then that is a clue to the fault. If your set has a Samsung panel then check for a light on the Y-main if it lights up then it has entered protect mode so you know it is likely Y-main at fault. Finally general fault diagnosis since it is intermittent temperature may be a fault so try heating and cooling things down and see if it works longer/shorter. Also if you have a variac try running it on low vs high supply voltage; I have seen issues where TVs work at 240V but fail at 235V.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • fanaticgames
      Philips 43PUS6703/12 screen flickering intermittent
      by fanaticgames
      Hi guys,
      I have this philips with this defect, I tried cleaning the flats of the t con but nothing changes, is the screen the problem??
      https://streamable.com/0zl6y3
      01-05-2023, 09:19 AM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • MarkC1970
      Red patches on screen. Driver fault???
      by MarkC1970
      I have a strange fault that I need help understanding. The TV is run with a PCB labelled TP.MS6486.PB711.
      As you will see in the pictures there is a red patch over the right hand side of the screen that is far more visible on a black background but never goes away. It appears like it is some sort of driver fault but I don't know enough about how these panels are driven to even guess where to start looking. Any advice would be greatly appreciated. Thanks.
      11-25-2023, 09:12 PM
