LG 50LA6205 Bad Backlight and Bad Panel
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4465
    • Italy - Milan
    Re: LG 50LA6205 Bad Backlight and Bad Panel
    Not.. the pixel colour information it's never been blocked, the blocked signals are only the ones that selects the rows where the colour info be displayed, since theese signals are sent and repeated from one side and the other in parallel, then eliminating one it's not so catastrophic, the design on big panels are that the gate signals are at both ends left/right because traces inside the glass has a relatively high resistance, thus the lack of one tension can become in some slight defects only in some cases, for example let we think if the screen is run at high temperatures, the resistance rises and a video defect can build. Led tv are very sensible equipments that i suspect can suffer also if in a room one let go an electrical machine with a strong spike at start like a motor, or if someone are doing heavy works with motor tools by the street or like..
    • Kevelade07
      • Apr 2019
      Hi Davi.p!
      Today I changed LEDs in a LG 50LA6250. I do this often, the LC500DUE panel is very prone to LED failure. Anyways, after my job, I started back up the TV and BOOM! Horzontal lines. But these were not the same kind of lines you see when a panel is damaged. They were dynamic. I was quite surprised at first because I do surgeries of this kind at least once a week and I'm very careful when I do this.
      I was ready to scrap the TV when I tried Google. I found your post and decided to give it a try. I had never done or even heard of this before! Well, after about 30 minutes I was able to find the right spot to tape on the ribbon. The picture has gone back to about 98% (one line slightly dimmer than the rest) and my customer will be very happy!
      Thank you very much for the information you shared on this post. It's very appreciated and there will be one less TV at the scrapyard
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4465
        • Italy - Milan
        Ok thanks..
        Usually it's possible to locate the pins without tries, when there are board markings..
        • Kevelade07
          • Apr 2019
          Unfortunately it wasn't the case for me. I was able to determine which lines were data and which were drive, so I knew approximately which ones I could disable. I wish I was able to find the datasheet of the LVDS driver. I would've loved to find the exact purpose of those pins... Thanks again :-)
          • neilc6
            • Nov 2015
            • 1550
            Tv came back again with 3 more shorted LEDs and I did a full backlight replacement with substitute strips from meihua361000 on ebay. Panel still looks good.
            • nomoresonys
              • 12276
              • U.S.
              #26
              Tv broke 3 times in 6months, the repair bill would probably be more than a new tv.
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • Sharx112
                ASUS VA27EHE randomly unstable
                by Sharx112
                Hello community. I've got an ASUS VA27EHE with a Panda LC270lf1l01 panel that started to behave strangely. A bit of intro:
                If you power on the monitor without any inputs it turns on, displays the ASUS logo, shows no signal and goes into standby normally. When you plug it via HDMI sometimes and more recently, most of the times, it distorts the bios logo with horizontal lines, then when loading into windows 50-50 the windows emblem also is in horizontal lines. And after the system loads it almost always works properly, lol. On some rare occasions a part in the top of the monitor is being distorted...
                03-26-2025, 03:42 AM
              • learnmore
                Samsung UE70TU7020K Which lines to tape on a bad panel
                by learnmore
                Hello Community,
                I'm working on a Samsung UE70TU7020K.
                It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
                I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
                03-15-2024, 03:01 PM
              • x_orange90_x
                Samsung UN46C8000XFXZA Horizontal lines
                by x_orange90_x
                I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                07-15-2023, 05:06 AM
