Philips 47pfl6008s level 2 blinks 53 after reflow
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4456
    • Italy - Milan
    Hi, initial fault: sometimes it doesn't power on, after a CPU reflow attempt it no more boots, i come fast to conclusion, i need help of some one also with the 42" model or some similar family model like 6007,7007,8008 series that is able to save the content of the settings eeprom and give me this file and its option table written on the back of tv. Help is highly appreciated! Please do a good action, i'm stuck on this tv since 1 year and half. I'm near to set it on fire.. bye.
  • goluins
    • Jul 2020
    • 46
    • Russia
    Re: Philips 47pfl6008s level 2 blinks 53 after reflow
    Hello I know how to fix your problem!Before my not resolved problem of Sony 55KD8505(i asked you to help me!) My first solved problem was 53 fault on Q.FU1.1e!and i have some experience about that!
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      I know the problem is the cpu soldering. Must to take some time to make experiments more on reflowing / reballing, the problem is widely common.
      • William1967
        • Nov 2017
        • 215
        • Netherlands
        NVM software for a QFU1.2. After programming the options etc must be aligned.
        • goluins
          • Jul 2020
          • 46
          • Russia
          I have two lcd panels Philips 40pfl7007t12 and 46pfl7007t12.On the first panel i was changed ssb of the second panel.Now i have 40pfl with ssb of 46pfl!now i have a problem with switching on, but after re-flashing eeprom with service dumps,i can switch on the tv only fist time!What do you think about this problem&
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4456
            • Italy - Milan
            It's obvious, why to take an unknown dump from somewhere and not to read the data from the original board and put it on the replacement one? But DON'T HIJACK OTHER ONE's THREAD! Open up your own one and discuss there.. Don't reply please!
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • alro7779
              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
              by alro7779
              Hello, guys!
              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
              09-14-2025, 12:25 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • Olvin1
              Acer nitro 5 an517-52 reflow/rebal CPU
              by Olvin1
              I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
              I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
              • A detailed temperature profile for reflowing this specific CPU
              • Step-by-step guidance for a safe and effective reflow process
              • Tips on what to watch out for during the procedure
              If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
              08-01-2025, 01:59 PM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
