Sharp LC-60E77UN: black screen and blinking power light.
  • Scollins
    • Sep 2018
    • 18
    I live in Florida and right now it is hurricane season and we have terrible lightning every day. During one of these storms this tv was knocked out and now the display won't turn on. An older couple gave this to me because they were getting a new one and this wasn't working. I assumed it wasn't truly bad and so have taken it in a done some research on the device and the error.
    From reading the service manual section 6-14 it appears to be a ERR_PNL (40pin): L error. I have tried every way listed online and in the manual to display the 'K' screen and reset the lamp errors to see what is wrong. I have had no avail and so I took the back off to see what was under the hood. I will comment pictures in a response comment from my phone.
    Has anyone had any luck in bypassing the lamp error check on boards like these? I read elsewhere that if you solder a bypass you can see if it is the power board or the leds. Will that work with this board?
    Or have I misunderstood what the manual was saying?
  • Scollins
    • Sep 2018
    • 18
    Re: Sharp LC-60E77UN: black screen and blinking power light.
    Here
    • R_J
      • 9552
      This set uses CCFL's not led's, The backlight inverter boards are under the shields on the right and left of the tv
      There are two boards on each side, check the plug connections between the two boards, sometimes the connections burn.
      to enter the service menu, unplug the tv, while pressing VOL (-) and INPUT keys, plug in the tv. The `K' should appear, Next hold down the VOL (-) and CH (▼)
      • Scollins
        • Sep 2018
        • 18
        R_J
        Thanks for the clarification about the leds and ccfls. The screen remains black when i plug it in while holding the Vol- and Input keys.
        Should I look at the inverter board for something that triggers the fault?
        • R_J
          • 9552
          You should look at those wire connectors between the two inverter boards, see post #3
          • Scollins
            • Sep 2018
            • 18
            They look normal. I unplugged them and plugged them back in without a problem.
            • R_J
              • 9552
              So you removed the shields to expose the inverters? check the small white fuses, there should be two on each of the large inverter boards, if they are ok, check the resistance on each output transformer, the resitance should be close to the same on all of them. Ifone checks open or lower than the others it would likely be bad. You could also have a bad ccfl.
              Try this: unplug tv, hold down [CH_DOWN] and [VOL_UP] and plug in tv, do the backlights come on?
              Or this: with tv pluged in and turend off, hold down [VOL (-) and CH UP and press power button once, release vol(-) and CH_UP and press power once more.
              • Scollins
                • Sep 2018
                • 18
                R_J, thank you so much. I don't know what I have done, but this time the combination of Ch_DOWN and VOL_UP worked and the display is back up and running. What did that combination of keys do exactly?
                • R_J
                  • 9552
                  I believe that is just a way to bypass the error and will only operate for a short time. If it does allow you to go into the service menu and reset the lamp error counter, check that all the lamps are working.
                  something else to check on these sets is to remove the inverter boards and check where the grounds meet the metal chassis, if there are black arc marks, clean them and reinstall the boards making sure the screws are fairly tight.
                  • Scollins
                    • Sep 2018
                    • 18
                    So it has been working for a day, but now it occasionally flickers brighter than the normal brightness. I plugged it into a different surge protector, which I read might affect it like such, but is there a way to check to see if it is the board or the surge protector?
                    • zyad
                      • Feb 2022
                      • sudan
                      Hello R_J , i have the same issue on my sharp aquos lc-50ue630x, i have tried this process holding down [CH_DOWN] and [VOL_UP] and the backlight went up while the screen is lighted there is nothing, how do i reset it to service menu or what should i do next. reminding my tv is sharp aquos lc-50ue630x
                      thank u
                      • KYBOSH
                        Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                        by KYBOSH
                        Picked this up to resurrect.
                        When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                        I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                        Sometimes the TV would produce an expanding blob on the screen before going black.
                        See Video here
                        I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                        Did I get another defective board or is there an issue with...
                        09-16-2024, 07:48 PM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • YasaCh
                        Sony kdl 40p5500 red light keeps blinking 3 times
                        by YasaCh
                        Hello...
                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                        i opened the back cover no sign of damage on the powery suply or motherboard
                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                        07-07-2025, 11:53 AM
                      • EazyBone
                        Sharp LC-65Q620U White Screen
                        by EazyBone
                        Another TV topic!!
                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                        08-21-2024, 12:56 PM
                      • Sam Scarbo
                        Brother DCP-L2540DW scanner/printer - only showing blinking screen in LCD.
                        by Sam Scarbo
                        I got this broken printer from my brother who got it from the street. He asked me to help to fix it.
                        I need help on fixing this machine.
                        Issues/Observations:
                        1) When connected to power, it's not working. Only showing blinking screen on the LCD. See pics 1 and 2. It is blinking every 2 seconds.
                        2) I pressed the buttons on the control panel to see if there is any response. The "Options" button can turn off the LCD screen, and then press hold the power button for about 1 second can turn the blinking screen back on again. Other than...
                        10-19-2023, 10:32 PM
