Lg 47lb582v blinking backlight
  • w3svc
    • Sep 2018
    • 7
    • Sverige
    I have a LG 47LB582V where the backlight blinks. Have checked and replaced all bad LED's byt it still blinks.
    I've messed arround the power supply and suspect it is faulty: see attached pic below.
    Any suggestions arround where the fault might be?
  • R_J
    • 9588
    Re: Lg 47lb582v blinking backlight
    I would put my money on faulty led's in the panel. If you want to be sure you would need to swap the two led strings around, or you could try swaping complete strips that are connected on the one string with the other and see how it effects the power supply voltage (does the lower voltage switch to the other pair of leds)
    You do not need to install the lcd panel to have the leds turn on and see which are lit up or flickering
    • w3svc
      • Sep 2018
      • 7
      • Sverige
      The result is the same reguardless on how I connect the led-strips. Tried that aswell.. Perhaps should have mentioned that
      • w3svc
        • Sep 2018
        • 7
        • Sverige
          Can we see the straight pictures of the whole top and bottom side of the power supply board?
          What is the P/N of the board?
          • w3svc
            • Sep 2018
            • 7
            • Sverige
            Originally posted by budm
            can we see the straight pictures of the whole top and bottom side of the power supply board?
            What is the p/n of the board?
            p/n: 3pcr00367b
              Originally posted by w3svc
              p/n: 3pcr00367b
              That is not the P/N of the board:
              Your pictures is not clear enough for me to read much of anything.
              The PCB P/N is EAX????????
              The PCBA P/N is printed on the barcode sticker.
              • petehall347
                • Jan 2015
                • 4438
                • United Kingdom
                65423801 (2) .1)... for eax
                barcode scanner cannot pick up the barcode
                • w3svc
                  • Sep 2018
                  • 7
                  • Sverige
                  that is not the p/n of the board:
                  The pcb p/n is eax????????
                  The pcba p/n is printed on the barcode sticker.
                  pcb: Eax65423801 (2.1) rev 2.2
                  • w3svc
                    • Sep 2018
                    • 7
                    • Sverige
                    See if this helps more.
                    • Trofazni
                      • Dec 2016
                      • 71
                      • Serbia
                      Hi to all!
                      I will jump into this thread, because I have the same problem, on the same power supply.
                      Anyway, leds are ok, one string replaced with new, second repaired, tested, and ok.
                      When it flickers, only the old, repaired set of leds is blinking, new installed does not. So, one of two power supplies for leds is faulty on pwboard. Checked caps, diodes, resistors, checked for shorts, everything seems ok, so I guess I am missing something.
                      In my opinion when leds died they draw too much current or made shorts and burned something in power supply in led pwm sector. I did some measuring on one diode i have odd voltage pulsing 3-4V, although voltage drop across diode should be 0,4V, Replaced it even it was measurin ok on multimeter voltage drop test, 0,4V, replaced it still, but everything stays the same.
                      On video you can see voltage on that diode, and two that go to led strips...
                      If anyone has idea or service manual, that would be great.. I bought new led, not knowing it has power supply problem.. Thanks
                      https://www.youtube.com/watch?v=4pei...ature=youtu.be
                      • R_J
                        • 9588
                        exchange both the + &- wires of the two led strings, that will tell you if it is the repaired string is at fault or the power supply. If the new string is working and the repaired string is flickering, I would suspect a weak/intermitint led in the repaired string.
                        • Trofazni
                          • Dec 2016
                          • 71
                          • Serbia
                          I will try that, although every single led in repaired strip is tester separetly, from begining to the end, even every one*s resistance to the chasis.. all measuring as should.
                          I will replace power lines of strings and write tomorrow when I get to work..
                            What is the spec of the replacement LED's?
                            Did you test as the whole string? I know you test individual LED.
                            BTW, is your TV the same model and same screen size?
                            If you look at the LED Voltage you will see that different screen size the two LED strings may not have the same Voltage due to the two LED strings may not be the same.
                            So be careful when swapping the LED wires.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              The working led voltage as seen in the picture (bit blurred) in post #6 looks as though it should be 117V for each string. What are you measuring?
                              • Trofazni
                                • Dec 2016
                                • 71
                                • Serbia
                                Ok, I solved it.. First I tried to swap power lines of 2 strings, came out the same situation.. So, I guessed that NEW strings are not working. Soldered 10 leds on a test board to imitate string and it worked. One of two new strings was bad. As i tested it, found out that one of 4 half strings (two A and two B), is making problems. When I isolated problem to only one half of string, I tested each diode, and they worked??? Checked for shorts to ground and else, all ok.. Finally I removed test leds, and suddenly everything is working without any changes. So, I am guessing that one solder point where connector is soldered was bad, when i soldered test leds, probably repaired contact not knowing it was problem.. I have no other explanation on this problem, taking that I did not change anything but soldering wires on connector points...
                                Thank for ideas, they really helped, I would not suspect faulty contacts on new strings that have been tested fine, one by one, even 3 in a series tested fine.. Did not have such an experience...
                                • Skeltek
                                  • Sep 2022
                                  • 4
                                  I got the same issue like in your video (my sisters TV broke down, the board is a PBC: EAX65423801 (2.2) REV 2.1 and the TV is an LG 55 something). The Backlight periodically turns up, then goes black again in 1 second intervalls, while sound and all other functionality seems fine.
                                  Looking closely, I saw 1 bright flash on all sides of the monitor (one can see the backlight shine through the sides, once the back panel of the TV casing is removed), followed by 2 dimm flashes. All seem to pulse periodically bright-dimm-dimm-repeat with a 1 second period.
                                  I unplugged the backlight power connector on the power supply and measured the voltage there. Without the backlight plugged in my multimeter shows 0V-4 2V-0V-8V-repeat. Maybe the voltage is higher, but the multimeter needs a fraction of a second to measure.
                                  Since I do not know how the PSU board reacts without the backligth plugged in, I could only presume it was a defect in the PSU board, since the voltage keeps pulsing even without the backlight being attached.
                                  Why does the voltage keep pulsing, even without the backlight being attached? Is the board defective as follow-up damage, or is it normal behavior of the PSU board, when something is wrong with the backlight? As I understood, a repair of the PSU board was not required in Trofaznis case.
                                  I did not quiet understand above descriptions though, since I am unsure what the difference is between a strip and a string in that context.
                                  Since I presume Trofazni is german (his TV shows german text) or croatian (like his profile indicates), maybe he could message me in private (I speak both languages among others) before I post my solution here.
                                    • 12276
                                    • U.S.
                                    could be a connection problem like this for example: https://www.youtube.com/watch?v=cfHPKs4UFfc
                                    • Skeltek
                                      • Sep 2022
                                      • 4
                                      Well, I got several broken LEDs, but most apparently all the stripes seem to be receiving power. Can LEDs short-circuit?
                                      I made a video and this is a screenshot of just during the LEDs flaring up.
                                      As one can see, almost every strip has at least one defective LED.
                                      I am going to order new LED strips, but I am unsure which one to order at which store.
                                      A search gives me all kinds of results, but none for an LG 55LF5809
                                      Also what remains is just the hope this would fix it. I would still probably have to wait until beginning of November to get them delivered.
                                      I also made an analysis on the psu board, but like I earlier said I am unsure how the board is supposed to behave when the backlight is not plugged in. It also seems to pulce the voltage, but that could be from there being no consumer and it shuts down then?
                                      • alfatv
                                        • Sep 2020
                                        • 353
                                        LED short circuit is typical.
                                        Any LB or LF strips should fit as long as screen size is the same.
                                        Light uniformity will never be as good as original.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • Davi.p
                                          Samsung UE49MU6120 no boot, no spy led, blinking backlight...
                                          by Davi.p
                                          Hi folks, the set is from my brother house, unfortunately i'm repairing 1 tv, 1 pc, 1 tablet, 1 Stereo receiver at the same time, all house's bench/table busy, i eat like an horse, and i'd like to know sure experience from other techs about this, i don't like to transport it to my house and it ends it is bad backlight waiting months for parts and so on..
                                          The blinking is only on the left side, no answers from remote, right after plugging in, back story of tv it had some slight B.L. problem, some shadowing in the bottom of image, maybe burnt sheets.. i really hope it's the same old spi flash...
                                          08-27-2024, 08:07 AM
