LG 66UH5500 won’t power up
  • Jason616
    • Sep 2016
    • 99
    When I push the power button the LG logo will flash then the tv goes black and the power light will flash twice and go dead .
    Does this sound like a back light problem or more like a power or main board issue ?
    Any help would greatly be appreciated
  • Mosijoon
    • Aug 2018
    • 5
    Re: LG 66UH5500 won't power up
    I had the same problem with this model but 50 inch. It's because of one burnt backlight. read this thread: https://www.badcaps.net/forum/showthread.php?t=67154
    • jjanssen7
      • Nov 2012
      • 252
      X2 I've repaired 5 or 6 of these. All had an burnt LED issue.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ipatch
        troubleshooting microsoft surface pro 4 no power no led charge light
        by ipatch
        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
        10-05-2023, 11:59 AM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! 🚀
        I have no idea what I’m doing, but I’m learning by trial and error.
        I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
        03-31-2024, 02:12 PM
        Laptop computer that went completely dead no boot no power light no hard drive light
        See pictures for type of laptop computer
        I checked switching power supply brick 19.2 volts multi meter only
        No booting without switching power supply connected
        Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
        What the heck is going on here...
        04-04-2025, 04:58 AM
