17MB55 problem
  • chrisB47
    • Aug 2016
    • 13
    • England
    17MB55 problem
    Hi guys. I have a Celcus DLED40125FHD with a VES400UNDS-03 screen and a17MB55 23182338 motherboard. The tv will not come out of standby and it is definitely seems to be a fault with the motherboard as I have tried a known good psu. I have tried freezing the memory chips but that didn't work. All voltages appear to be there. When I try the on button on the remote the set will flash the standby light 6 times and then go back to steady red. I was going to just buy a secondhand board for it but there doesn't appear to be any with the correct part number available online. Do any of you know if there is another board that would be a suitable replacement for the 17MB55 with the 23182338 part number? Or do any of you have a 23182338 that you could sell me?
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: 17MB55 problem
    Have you tried flashing another firmware? These boards are very specific so you have to match everything and usually there are no replacements. I can try and find you the correct board but I have to order directly from the factory. Let me know if you are interested and if you can wait for it. Thanks
    • chrisB47
      • Aug 2016
      • 13
      • England
      Re: 17MB55 problem
      Hi Ducky, thanks for that. I haven't tried flashing the firmware as I wasn't sure if the firmware would be generic for all the 17MB55 boards or if it would be specific to this part number. Also, to be honest, I didn't know where to get the firmware. Is there a website that I could download it from?
      As regards your offer of asking about a replacement board. It would be interesting to know if the cost would be low enough to make this an economic repair. The tv is one I picked up for free and is only worth about £60 if it was in working order, so for a repair to be economic a replacement board would have to be around £35.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Re: 17MB55 problem
        Have you checked in the eeprom dump thread you maybe lucky and its in there can you post a picture of the sticker on the back of the tv the one with the model number on
        https://www.badcaps.net/forum/showthread.php?t=59877
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Re: 17MB55 problem
          The firmware is specific for the tv. I can supply the firmware for 5$ as I also pay a monthly fee for them. Ill ask my supplier and Ill get back to you.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Re: 17MB55 problem
            is the firmware updated via usb on these or do you need too remove ics? ive never done a 17mb55 just curious
            • ducky29
              • Dec 2015
              • 369
              • Europe
              Re: 17MB55 problem
              Usb like all vestels, you can also do it by removing the ic's but the usb method is more convenient.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                Re: 17MB55 problem
                can you get most vestel firmware? its handy too know as i have had a few ive had to replace the board on as could not find the firmware for them.
                • ducky29
                  • Dec 2015
                  • 369
                  • Europe
                  Re: 17MB55 problem
                  Yes I can get almost all of them. Thats the best option if you cant find the firmware but unfortunately its very expensive replacing the mainboard.
                    Re: 17MB55 problem
                    You can also try the method I outlined here by using the UART port exposed on some Vestel TV SCART ports. But it requires some Linux hacking-around experience.
                    https://www.badcaps.net/forum/showthread.php?t=62824
                    • chrisB47
                      • Aug 2016
                      • 13
                      • England
                      Re: 17MB55 problem
                      Hi Ducky, I would be more than happy to pay you for the firmware and would be most grateful if you could get it for me. My email is: chrisbarker47@sky.com if you wish to email me privately we can arrange payment etc.
                      Thanks.
                      • chrisB47
                        • Aug 2016
                        • 13
                        • England
                        Re: 17MB55 problem
                        Just a quick update for you. Ducky very kindly emailed me the firmware for the board and after loading it into the board, using a usb stick, the tv started up and now runs okay. The firmware Ducky supplied was excellent and loaded into the board very easily in about 5 minutes
                        Many thanks to Ducky and thanks to you others that offered help.
                        Chris.
                        • mo4nis
                          • Dec 2018
                          • 55
                          • maroc
                          Re: 17MB55 problem
                          VESTEL 17mb55 model VES236WNEC
                          • DualZyclone
                            • Jan 2024
                            • uk
                            VESTEL 17MB55 (23189260) board firmware required!!
                            This is from a TV model = Celcus DLED40125FHD
                            with a VES400UNDS-03 screen. other numbers from the TV are [10089464] [27148104] may help in identification
                            • DualZyclone
                              • Jan 2024
                              • uk
                              Now fixed by reflashed the firm ware with bornova_usb_update.bin and bornova_usb_update.scr from "17mb55-v030h-r126232-bornova-pack-xls.zip"
                              Big thank you to ducky29
                              As a thank you I am posting the following information to help others :-
                              (1) Format a USB memory stick/ usbpen drive to FAT32
                              (2) copy the files *******.bin and ******.scr to top level (root) of the drive { NOT in a folder }
                              (3) unplug TV from the mains power
                              (4) place the USB stick in back of the TV
                              (5) HOLD down the [OK] button on the remote control and point at the TV
                              (6) while keeping the [OK] button pressed, plug the TV back into the mains power
                              (7) the power LED will flash FAST (about 3 times a second)
                              (8) still keeping the [OK] button pressed down, count to 19 seconds then release
                              (9) the power LED RAPID flashing will continue for a few minutes
                              (10) just WAIT and do not remove the TV from mains power, the power LED will go off, then the TV will start UP
                              VESTEL Engineer codes from the WEB
                              To get to the Service Menu
                              Press the Menu button on the Remote.
                              Press 4725 buttons in quick succession.
                              OTHER Vestel TV's Service Menu codes
                              WHARFEDALE, HITACHI = MENU, 1461
                              ?? = Menu 1 9 2 3
                              Calibration Menu - Press the Menu button on the Remote, Press 4726
                              Hotel Mode Instructions (Warning - some users have got the TV stuck in hotel mode)
                              Method 1 - Menu, 1325 [Enter Hotel Mode]
                              Method 2 - Menu, 7935 [Hotel Mode]
                              PIXEL perfect SCREEN capture ability in VESTEL TV's with a USB socket!!!!
                              In the SERVICE menu
                              Select "Diagnostic" item on the menu
                              press OK
                              you'll get a secondary menu with a list of choices on it
                              Go down to the bottom of that menu
                              you should see a "Screen Capture" option
                              Enable it
                              then press "back" key on the remote repeatedly until your back at your normal TV display
                              you'll find your POWER button no longer works on the remote control.
                              your POWER button has been turned into a SCREEN SHOT button.
                              If you put a USB Thumb drive into the usb slot on the back of the TV.
                              Every time you press the power button, the display will be captured to a graphics file on the thumb drive, the screen shot will grab what ever is displayed on the panel, no matter what it's source is.
                              Pixel Perfect screen shots every time :-)
                              So anything you can plug into the ports, composite video, HDMI, Scart etc, can be captured.
                              Doesn't matter if it's a DTV channel, SkyBox input, Chrome cast, BBC Micro or web application such as Plex
                              As long as the TV can display a picture from it, you can SCREEN grab it to an image file.
                              Repeat the menu steps above and go back in to "Disable" the feature in order to return your remotes power button to normal.
                              note: the credit for the screen capture information is from a post made by Shawty
                              https://stardot.org.uk/forums/viewtopic.php?t=18673 Thu Feb 06, 2020
                              • ducky29
                                • Dec 2015
                                • 369
                                • Europe
                                Sent you a link on pm
                                • DualZyclone
                                  • Jan 2024
                                  • uk
                                  Logic board = VESTEL 17MB55 (23189260)
                                  Power board = 17IPS20 23152101
                                  The tv did not come out of standby and it was a logic board fault, as I tried a known good Power board.
                                  Fixed by reflashing the firmware SEE post #15 by me for instructions or the following text . I tried to put these pictures onto that post, but it would not let me
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • Zeonalbasta
                                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                    by Zeonalbasta
                                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                    09-13-2024, 01:17 PM
                                  • Gibon378
                                    Problem with stopping audio and video for no reason
                                    by Gibon378
                                    PC Specs:
                                    • CPU: Ryzen 5 1600
                                    • GPU: GTX 1080 Palit JetStream
                                    • MOBO: ASRock ab350 PRO4
                                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                    • PSU: XFX 650W (don't remember what model)
                                    • OS SSD: ADATA SP920
                                    • OS: Windows 10 21H2
                                    Problem description:
                                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                    11-19-2022, 09:41 AM
                                  • perzyk23
                                    Lenovo T580 - LCD Panel problem - error 0288
                                    by perzyk23
                                    Good morning,
                                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                    10-25-2024, 12:42 AM
                                  • lazaro.089
                                    Asus Zephyrus M16 / GU603ZW problem
                                    by lazaro.089
                                    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                    CPU: Core i9-12900H
                                    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                    08-26-2025, 06:33 PM
