Vizio XVT3D554SV with red "sploteches"
  • mrfixit95
    • Aug 2018
    • The Moon
    I have an interesting issue with my TV. When turning on "cold" (been in standby for a few hours), the screen comes on with red "splotches" that flicker for a while until it warms up. After it warms up, the splotches are gone.
    I've done a factor reset, but the problem exists even when booting with the logo shown on the screen; you can see some red "artifacts" flickering on the silver/white Vizio boot logo.
    • All inputs work (with sound) but I didn't test the VGA input (I don't have a source that old anymore)
    • Menus work and "flow" smoothly
    • Nothing freezes
    • Screen is crisp and clear, no distortion whatsoever.
    • Even with the red splotches, the picture itself is good
    My "hypothesis"
    I think there is a cold solder joint somewhere, but I don't want to go replacing components willy-nilly. I think it may be the T-Con board and a failed component/connection. It also sounds like it could be a power supply where the voltage may fluctuate until it warms up.
    I'm a novice at board level repair, but it's not entirely foreign to me. If someone could point me in a direction to begin troubleshooting (or if you've seen this before), I would appreciate it immensely.
    Thanks for your time!
    Re: Vizio XVT3D554SV with red "sploteches"
    "you can see some red "artifacts" flickering on the silver/white Vizio boot logo." But we cannot see anything. You have the TV we do not.
    • Bob1394
      Vizio M65-C1 | Logo appears for 10 seconds then off
      by Bob1394
      I have used the search, and am stumped.
      My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
      I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
      https://www.badcaps.net/forum/showthread.php?t=81088
      https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
      Observations
      1) [Interaction] Power turned on via TV button (or remote)...
      02-08-2023, 01:03 PM
    • Super360
      Vizio E701i-A3 Vizio logo flashing then turns off
      by Super360
      Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
      07-25-2024, 07:06 PM
    • x_orange90_x
      Vizio V555-G1 stuck on wallpaper; now stuck on V logo
      by x_orange90_x
      I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
      12-28-2023, 06:26 AM
    • JaquesPratt
      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
      by JaquesPratt
      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
      07-16-2024, 01:04 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
