Vizio E48u-D0 not turning on, Pwr LED on and off
  • solderfly
    • Mar 2013
    • 13
    Hi everyone.
    Working on this LED TV.
    TV started with sound issues, would make like interference noise. One day it just did not turn on anymore.
    Replaced the power board already but no change in symptoms. TV makes no sound, has no picture but pwr LED is on. Upon remote power on, the pwr LED goes brighter and then slowly dims to off. The pwr LED does come on and goes off infrequently.
    On the main board connector J4 at top of board shows 18V on pin 1-4. I only measure 17.5V. Would that be an issue?
    Pin 9, PS-on, has no value printed but I measure 3.3V.
    Pin 10, BL-on, never shows any voltage.
    Is there some measurements to determine bad main board or bad BL LED?
    Thank you for your help.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
