Phillips 55PFL5601/F7 - No Standby, No Power, Fluctuating Voltages...
  • grimacelord
    • Jan 2017
    • 380
    Hi. I have a Phillips 55PFL5601/F7 here with some problems that I can't pin-point the cause of.
    Some history on the TV, it was brought in to me after it suffered a power surge/lightning strike. I was able to find both the power and the main board pretty cheap and for the sake of time, I went ahead and bought both. Replaced both the main board and the power supply board and the TV exhibits the same symptoms as it did with it's original boards:
    1. No standby LED.
    2. No display.
    3. Voltages on the power supply side fluctuate wildly, not stable.
    4. One of the transformers is making a buzzing sound every 1/2 second or so. "Buzz, buzz, buzz, buzz, buzz, buzz" - as soon as it's plugged into power.
    I have done some minor troubleshooting steps already, like checking the fuses and trying to get some voltage readings on the pins, but as I said, they vary wildly so I can't get anything stable.
    I have tried disconnecting (one at a time and testing after each one) everything except for the power and main board and of course the AC power cable. I did check and saw 121VAC from the wall outlet, just to make certain.
    So being that both boards are exhibiting the same symptoms, what is going on? Could the two main cables between the two boards somehow cause this? What are the chances of receiving two ("new") boards that show the exact same symptoms?
    Here are some photos for ya.
    EDIT: I added a pic and circled the transformer that is making the "buzzing" sound every half second or so.
    Re: Phillips 55PFL5601/F7 - No Standby, No Power, Fluctuating Voltages...
    1) Is the power supply board still buzzing if you run the power supply board on by itself?
    2) Have all the board connected together and then check the resistance between
    GND and J623 (P-ON+21V)
    GND and J620 (AMP+3.3V)
    GND and J621 (ALL+3.3V)
    • grimacelord
      • Jan 2017
      • 380
      1) No, the power supply is quiet when only it is plugged in and powered on.
      2) Resistance between the jumpers you listed and GND is as follows:
      J623-13.9 and dropping
      J620-0.L
      J621- 58.0
        "J623-13.9 and dropping "
        Look for SMD cap C3214 on the main board and check its resistance.
        Similar problem:
        https://www.badcaps.net/forum/showth...214#post841636
        • grimacelord
          • Jan 2017
          • 380
          Similar problem:
          I'm having trouble locating a capacitor labeled as C3214 on my main board. I've looked over it several times. In fact, I cannot find capacitors in the C32xx range at all. They go from C30xx, C31xx, C33xx, etc.
          I cannot find a single C2xx labeled capacitor anywhere. Maybe I'm just blind though.
          BA51REG0401 2 is the main board number.
            In this case we need to find the service manual for the main board or you will have to trace the P ON+21V to see where it goes to on the main board, there will be many places.
            Please look at the back of the TV where the model number sticker is, see what the Chassis number is.
            Is it PL 11.8?
            • grimacelord
              • Jan 2017
              • 380
              Is it PL 11.8?
              I don't see anything about Chassis number.
                This is going to tough, I cannot find the service manual for this model, the closest one I found is for 5706.
                • grimacelord
                  • Jan 2017
                  • 380
                  I found a service manual that lists my model on the cover page of it.
                  I attached it to this post. Is that what you need?
                    Yep!
                      Which website did you go to?
                      • grimacelord
                        • Jan 2017
                        • 380
                        www.electronica-pt.com - It's in Portuguese, but it had what I was looking for.
                          It looks like you have type F main board, so look at all the caps connected to the P-ON+21V to find out which one is bad.
                            That is where I went, I missed it some how.
                            • grimacelord
                              • Jan 2017
                              • 380
                              Alright. So I tested C3606, C3641, C3639, C3731, C3624, C3630, C3734, C3735, C3631. I also tested D3602, D3604, R3610, and R3612. Everything seems to be in working order. The ones that are marked "OPEN" on the schematic are not present on the board.
                                None of the resistance reading on those caps show 13.9 Ohms that you indicated in post #3 when reading the resistance between GND and the P-ON +21V?
                                • grimacelord
                                  • Jan 2017
                                  • 380
                                  I changed probes and then took new readings of GND and J623 (P-ON+21V), GND and J620 (AMP+3.3V) and GND and J621 (ALL+3.3V). They read differently now.
                                  J621 0.5 then drops to 0.3 and holds
                                  J620 0.4 then drops to 0.2 and holds
                                  J623 0.4 then drops to 0.2 and holds
                                  Sorry about that. Are these numbers more in line of what we would expect to see?
                                  I think it's worth mentioning that it still doesn't produce a standby light or power on. There is still that pulsating buzzing noise too.
                                  I decided to go back and take resistance readings of each of those caps a second time with the new probes. Here is what I got:
                                  C3606, 4.81, dropping
                                  C3641, 4.69, dropping
                                  C3639, 4.71, dropping
                                  C3731, 4.6, dropping
                                  C3624, 4.9, dropping
                                  C3630, 4.9, dropping
                                  C3734, 4.6, dropping
                                  C3735, 4.61, dropping
                                  C3631 - 4.2, dropping
                                    Are you setting the meter to Ohm mode and the TV is not plugged in?
                                    What are those readings? Ohm, DC Volt, AC Volt?
                                    They do not make any sense to me, they cannot be showing less than 1 Ohm on all those jumpers.
                                    • grimacelord
                                      • Jan 2017
                                      • 380
                                      Yes. Meter set to Ohm mode and TV is not plugged in. All boards are connected to each other properly.
                                      The readings were all taken in Ohm mode.
                                        1) So are they 0.5, 0.4, Ohms, K Ohms, M Ohms.
                                        2) What resistance scale do you have the meter on: 200 Ohms, 2K Ohms, 20K Ohm, etc.
                                        3) What did you use for GND for the meter?
                                        It is impossible to all 3 power supplies output showing <1 Ohm.
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • triplefour
                                          ONN 100012588 Has fluctuating Voltage on PSU 12v
                                          by triplefour
                                          Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                          anyway i go to this guys house to look at an ONN 100012588
                                          this is my first time looking at one of these brand of TV's.
                                          TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                          09-14-2022, 07:41 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
