Sharp LC-52LE830U no backlight
  • 73buick
    • Mar 2011
    • 41
    Re: Sharp LC-52LE830U no backlight
    Okay, I got it into the service menu. Only problem is now I think I do need the remote as the instructions say to press OK after highlighting the L ERR RESET line, but there is no OK button on the set and the service manual says OK is just on the remote.
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Misterfixit
      Sharp LC-58Q7330U No Backlight
      by Misterfixit
      This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
      06-04-2023, 07:39 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • Misterfixit
      sharp LC-50LB601U No backlight
      by Misterfixit
      I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
      04-04-2023, 01:21 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
