Samsung UE32D4003BW Backlight problem.
  • Gemat
    • Nov 2014
    • 23
    • Ελλάδα
    I have a relatively new Samsung UE32D4003BW TV with not many hours of service that has a problem with the backlight.
    When the TV starts, the backight lits to normal brightness, but after a few seconds the brightness drops and the leds flicker.
    If the TV stays on for half an hour or so, the brightness gradually increases and the TV works fine for as long it stays on.
    I tryed factory resetting the TV.
    I send the boards to a local service store and they said it is a mainboard problem and cannot be fixed....
    Here is a short video of the problem...
    https://youtu.be/lkanGgAyHzo
    Any ideas??
  • Gemat
    • Nov 2014
    • 23
    • Ελλάδα
    Re: Samsung UE32D4003BW Backlight problem.
    Here are a couple of closeups near the led output socket....
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      do you have a multimeter? Maybe an oscilloscope?
      First I would measure the LED+ to LED- (I don't see from here, are there only 2 wires going to the LED stripe?)
      You need to see, if the voltage fluctuates also, or is it just the leds? Then you should measure the driving signal, is it stable?
      Cheers, Janos
      • Gemat
        • Nov 2014
        • 23
        • Ελλάδα
        I do have both a multimeter and an oscilloscope .
        When the tv starts the voltage is 130 volts and the back light is correctly lit.
        After a few seconds the voltage drops to 80-90 volts and the leds flicker and the brightness is low...
          Try turning down the backlights level to as low as possible to see if it will stop flickering.
          • Gemat
            • Nov 2014
            • 23
            • Ελλάδα
            Do you mean lowering the backlight from the tv menu?
            I have already done that. When to voltage is at 80 volts or below, changing the brightness from the menu makes no difference...
              Backlights level is not the same as Brightness (for Video) level.
              BTW, the Voltage on the LED connector pins should be measured with ref. to chassis GND.
              • Gemat
                • Nov 2014
                • 23
                • Ελλάδα
                The measurements I took were between the two cables going to the led stripe.
                After half an hour or so the voltage gradually increases to 120 and the backlight is correct.
                The intense flicker happens at around 100 volts.
                I didn't think of checking the output with the oscilloscope ...
                I will check it and let you know.
                Thanks for looking into my problem...
                  You need to check the LED+ with ref to GND when it is acting up, the LED+ is the Anode of the LED string which is fed by the boosted Voltage from the boost converter circuit.
                    BTW, if you disconnect the cable between the power supply and the main board then apply power to the TV, the backlights should come on right away and stay on without any flickering, if that is the case then the power supply and the LED backlights are OK.
                    • Gemat
                      • Nov 2014
                      • 23
                      • Ελλάδα
                      I will try it on Monday and get back to you...
                      • Gemat
                        • Nov 2014
                        • 23
                        • Ελλάδα
                        This is exactly what happens.... The leds come on and stay on!
                        • Gemat
                          • Nov 2014
                          • 23
                          • Ελλάδα
                          So, the local service was right that it is a mainboard issue....
                          Can I do anything about it? Like force the psu to output a fixed 120 volt to the leds so I can use the TV? I dont mind if I cannot change the brightness from the TV menu....
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            on the power supply theirs a pin on the connector marked blu on/off does that voltage change when the set is powered on test it in standby and set turned on im wondering if this is the voltage that tells the mainboard too turn the back lights on
                              If all other functions of the main board are OK, then you can try just having the BLU ON/OFF wire disconnected (and may be the dim control wire too) but all the connectors are back in place, after that when you power up the TV you should then see the pictures and all the functions of the TV should work, if not then you have more than just backlights on command signal problem.
                              • Gemat
                                • Nov 2014
                                • 23
                                • Ελλάδα
                                Here is another find....
                                The pin 14 on the main board (Dim_Out) , outputs 1V volt when I turn on the TV, but drops to 0,3 after a second and stays there.
                                All the other functions are working fine.
                                How can I manually output 1 Volt there??
                                Here two Pictures under and over the board zoomed near the plug.
                                  So right now you are able to get the backlghts to come on and able to see image on the screen, and get sound, etc. correct?
                                  If you go to on screen backlights level adjustment (DIM), can you set the backlights level at all?
                                  • Gemat
                                    • Nov 2014
                                    • 23
                                    • Ελλάδα
                                    I have cut the Dim_Out cable from the board to the PSU and I have reassembled the TV .
                                    The TV works with max backlight, a solution that is not perfect, but I am OK with...
                                    All the other settings except brightness, like sound, colour, etc. work fine....
                                      So let me get this correctly, if the dim wire is not cut, you will not get the backlights either? What Voltage do you get on the DIM pin of the power supply board?
                                      There are ways to dim down the backlights level to make the LEDs last longer.
                                      • Gemat
                                        • Nov 2014
                                        • 23
                                        • Ελλάδα
                                        If the wire is not cut,
                                        when I turn on the TV it outputs 1volt and the leds lit full.
                                        after a second or two the voltage will drop to 0,3volts and the leds lit very low...
                                        If the wire is cut, the leds lit full all the time...
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                          09-07-2024, 05:50 AM
                                        • sandinemail@hotmail.com
                                          Samsung BN44-00284A Backlight problem
                                          by sandinemail@hotmail.com
                                          Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                          In November 2020 the TV didn“t turn on only flashing red diod on front off TV.
                                          I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                          I changed all capacitors except the main two 450V 100uf capacitors.
                                          The TV has worked pefectly since.
                                          But this week it started to turn off the backlight. Audio on TV still works.
                                          Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                          Any suggestions on what might...
                                          02-15-2023, 05:10 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
