P&F (Philips) 55PFL6900/F7 Turns on 3seconds then Off
  • Shock2cure
    Test Subject
    • Jul 2018
    • 140
    2015 55PFL6900/F7 4K
    Got this dumpster TV this morning while taking out the trash, couldn't believe there was a 55" in there with an intact display, ya know I had to haul it home
    What's more amazing is it doesn't seem to be much wrong w/ it.
    Plug it in to AC, get a relay click, hit power button, it all lights up nice....for about 3 seconds, then shuts off, then 5 seconds later the tos-link for optical audio LED light on main board goes out as well. (Telling me not a backlight issue, I at least unplugged back light power, it does the same thing) I'm going to check voltages here shortly (I got to go look at a potential Home Theater Job for a house @ 2pm) But I figured I'd stick this up now with some pics hoping maybe there's a case history issue or if somebody's dealt with this issue before?
    BBL!!!
    "Our technologies have surpassed our humanity" ~Einstein
  • Shock2cure
    Test Subject
    • Jul 2018
    • 140
    Re: P&F (Philips) 55PFL6900/F7 Turns on 3seconds then Off
    Here's what I got voltage wise from CN657 off PS board
    see pic for pin out
    pin5=3.3v stby
    pin6=0v stby - 3.3v power On
    Pin8=0v stby - 3.3v power on
    Pin9=3.3v stby
    Pin10=3.3v power on
    Pin15=12.9 stdby - 21v Power On
    pin16=12.9 stdby - 21v Power On
    pin17=12.9 stdby - 21v Power On
    Pin18=12.9 stdby - 21v Power On
    pins 23,24,25,26 all same= 8v stby - 12.8 power on
    PS: All Power-On voltages drop to 0 when SPDIF light goes out
    • Shock2cure
      Test Subject
      • Jul 2018
      • 140
      I'm thinking it's a fakked main board, these huge heatsinks make me think it's a BGA lift failure
      still not sure, don't have pinout voltages labeled nowhere nor a service manual
      • Shock2cure
        Test Subject
        • Jul 2018
        • 140
        may try a BGA re-bake in my Hasbro Easy-bake oven,lolz... Got nothing to lose there...lolz
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That's known as the "oven trick", over at Overclockers.com, IIRC.
          Seems to be very popular with video cards...
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Shock2cure
            Test Subject
            • Jul 2018
            • 140
            ya, I resurrected a couple Nvidia GTX 8100's & a 9500 that way, just wish I was 100% sure this is the problem here, PS board seems to have all the right voltages, cant see nothing physically bad on this main board, those two huge heat sinks soldered clamped to the board tells me they had issues with that wonderful BGA solder technique here maybe
            • Shock2cure
              Test Subject
              • Jul 2018
              • 140
              Tried the ez bake method today, actually, took off heat sinks and hit them with the heat gun ....to no avail, still does the same thing ;(
              • R_J
                • 9556
                I would suggest you have bad backlights, when you said you unpluged them and got the same result, that would indicate an open led string.
                It looks like there are four seperate led strings in this panel. I would place your meter probes across each string and turn on the tv. the voltage should come up then drop lower, post the voltages of each string
                CN1101 pins 1&2
                CN1201 pins 1&2
                CN1201 pins 3&4
                CN1401 pins 1&2
                You can measure each pin with ground as reference or measure across each pair of led's
                • Shock2cure
                  Test Subject
                  • Jul 2018
                  • 140
                  CN1101 pins 1&2 43.5v
                  CN1201 pins 1&2 47.7v
                  CN1201 pins 3&4 33v
                  CN1401 pins 1&2 41v
                  Thanks,
                  see pic
                  CN1201 pins 3&4 33v
                  CN1401 pins 1&2 41v
                  • R_J
                    • 9556
                    I would think they should all be close to the same voltage, this seems to indicate a problem with cn1201 3&4 diode string. Being that the voltage is low could indicate shorted leds in the string trigering an error.
                    By chance if you unplug cd1201 only do you get a flash of the backlight?
                    • Shock2cure
                      Test Subject
                      • Jul 2018
                      • 140
                      yes, unplugging CN1201 still gets leds lit + gives me 2 more seconds of LED time ..lol
                      • Shock2cure
                        Test Subject
                        • Jul 2018
                        • 140
                        well if its LEDS, this TV's still screwed, I have the worst record of removing the displays and breaking the sh*t out of them...bummer. Guess the Boards going on flEbay I reckon
                        • Shock2cure
                          Test Subject
                          • Jul 2018
                          • 140
                          well I rigged up a couple outside LED strips from another Set and plugged them into CN1101 & CN1401
                          I then took the end plugs from CN1101 & CN1401 and connected those into CN1201.... Hit power button and....see pics
                          Everything is staying on, R_J, you were spot on sir, bad/burnt LED array within the CN1201section....which normally I would rejoice, but as I stated, I have a 0% recovery when trying to replace LED's, I ALWAYS end up breaking the displays, I dunno if it's because I'm a bull taking these apart or simply cursed. But either way this one is still going to be broken because I'm not ruining my day when I break this 4K display trying to replace LEDS....lolz....
                          ...bummer
                          • Shock2cure
                            Test Subject
                            • Jul 2018
                            • 140
                            Well after sitting here staring at this sipping the morning Joe, I ripped it down...can still sell the working boards after i probably kill this display glass...lolz
                            -First Picture-
                            There's a total of 8 strips, 4 w/ 7 LEDs, 4 w/ 6 LEDs,
                            layed out in 4 pairs of 2, (1 w/ 6 leds. 1 w/ 7 leds)
                            52 LED's total
                            CN1201 drives the middle two rows
                            CN1101 drives top roww
                            CN1401 drives the bottom row
                            -Second Picture-
                            Red stars indicate the burnout LEDs
                            So 8 out of 52 are shot, 5 of them are connected to CN1201, so I see why the voltage was way off
                            I'm going to see if I got these LED's already, good chance I do,
                            still knowing I'm probably going to crack the helloutta this display putting it back...lolz
                            .......Well nothing from nothing is still nothing I reckon
                            RIP Billy Preston
                            • Shock2cure
                              Test Subject
                              • Jul 2018
                              • 140
                              I got every LED strip known to man.....except these...it figures, lolz
                              • Shock2cure
                                Test Subject
                                • Jul 2018
                                • 140
                                anybody knows where I can get these LED strips (not jimmys high dollar shop) drop me a PM, fleBays got squat, amazon's iffy, ali babba or whatever its called is scary,
                                thanks in advance
                                • R_J
                                  • 9556
                                  These might be them, check the part number on them, https://www.shopjimmy.com/catalogsea...q=UDULED0SM050
                                  Or http://www.tvpartsguy.com/products/p...led0sm051.html
                                  I think they are UDULED0SM050
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    How did you move the glass display? probably you can get a pair of vacuum cups to help you replace the glass when you are ready to close her up. For larger screens like yours I use a pair of that carry 4 vacuum cups each. Sorry I don't have a pic to post of them.
                                    • Keshenatech1
                                      • Apr 2018
                                      • 149
                                      I've done a lot of LED strips on TV's up to 65" and haven't broken one yet. (knocks on wood lol). What I use is the front and back panels from an empty cereal box. 1st tape the ribbon cable boards to the top of the screen with masking tape being careful to not stress the ribbon cables. Masking tape is good because it removes easily and won't leave any sticky residue on the screen. Carefully work the cardboard sheets under the display glass and carefully slide all the way around to unstick any spots that may be stuck down. Then position them in the center of the top and bottom edge with only a couple inches sticking out. Then carefully lift it from underneath with the cardboard trying not to touch the bottom side with your bare hand. It helps to fold the cardboard about 2" from the edge then you can grab the edge of the screen with the fold. And usually when I do this, I have it sitting on the floor and put down an old beach towel next to it to set the glass on so I don't have far to go. The key is holding it top and bottom center, not the long way on the left and right side, or it will buckle in the middle and break just about every time. Take your time and go very slow. You don't want any sudden motion to make it bend, or even worse bump into something with it.
                                      Btw I found this thread because I'm working on a Philips 55PFL4901 very similar model with the exact same symptom. When I get back to the shop tomorrow I'm going to measure the voltages on the individual LED arrays and suspect I'll find a similar issue.
                                      • pick1e
                                        • Oct 2018
                                        • 4
                                        Did you have any luck with this? I have one doing the same thing.
                                        • alpersen
                                          Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                                          by alpersen
                                          Hello
                                          Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                                          07-25-2024, 12:50 AM
                                        • ressof
                                          Philips 47PFL4606H/12 turns off after 10 minutes
                                          by ressof
                                          Hi
                                          I have a Philips LCD 47PFL4606H/12 that turns off after around 10 minutes and then i cant turn i back on again without removing the power cord and attach it again. Then it turns itself off again after some minutes. When this happens the red led that usually indicates standby mode is off.
                                          Can it be the same problem as in this thread?
                                          https://www.badcaps.net/forum/showth...ght=47pfl4606h
                                          01-23-2023, 12:52 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • Tyrmas
                                          Philips 58PUS6809/12 doesn't turn on - LED turns on for a second and TV clicks
                                          by Tyrmas
                                          Hi all!
                                          A few days ago my TV suddenly turned off while watching Netflix from my media PC. Only connected cables were HDMI and TOSLINK. It immediately started doing this loop where the power led turns on for a second and then turns off. You can also hear a click inside the TV every time.
                                          I tried the easy stuff first like disconnecting everything including the power cord but that didn't fix the issue.
                                          Now I opened the TV to check if there are any bad capacitors but as far as I can tell, they look okay.
                                          I've attached a few pictures and...
                                          08-24-2021, 04:33 AM
