Sony KDL-37M4000
  • fcisolutions
    • Jan 2017
    • 205
    Sony KDL-37M4000
    Have this Sony 37" television. Getting a light blue screen and nothing else. Thinking it could be the main board but wanted to get some advice. Tested T-Con and PSB and both good. Cannot get any buttons to work except for power button. No volume, menu, or input button control.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Sony KDL-37M4000
    disconnect one ribbon cable from the t-con and see if you get half a pic, then try the other half.
    this is where scoping the lvds would let you know if the t-con is getting a signal or not.
    is the t-con fuse good?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4460
      • Italy - Milan
      Almost surely bad mainboard, probably bad flash or bad main software.
      Check a service manual for the existence of a firmware recovery and reflash method by usb key if present or a method through serial port.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        i need more coffee i think. yeah, looks like eeprom if buttons are working but no change in status. though is power on/off working?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4460
          • Italy - Milan
          Yeah you need more coffe:
          it is written on the 2 little rows of text :-)
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            just need conformation that it powers off as well as on.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              The light blue screen tells us the backlights and the PSU is OK. Since the buttons are not working it is most likely a Main Bd. issue. As suggested before it may be an eeprom/software issue on the Main Bd. What is the Main Bd. Part No.??
              • fcisolutions
                • Jan 2017
                • 205
                Yes I can power the tv on and off. I figured it was probably the eprm on the mb.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4460
                  • Italy - Milan
                  No the eeprom no, cause a wrong panel setup ususally end in bad video not black but on top of all, remote and keyboard are not programmable so them must work.
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • iglitare
                    by iglitare
                    09-04-2025, 07:13 AM
                  • thelankanguy
                    Sony KD-55X9000F TCON Issue
                    by thelankanguy
                    The TV shows a black screen with no image.
                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                    Later both ribbons were disconnected and TCON voltages were tested.
                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                    There is also a short to ground in this circled inductor.
                    Is this a TCON issue or something else ?...
                    12-13-2024, 12:27 AM
                  • bbrain
                    Sony KD-55AG9 TCON?
                    by bbrain
                    I have this problem with my Sony 55' AG9.
                    It flashes 4x.
                    I have found the service manual, and seems it is the TCON.
                    Before I buy a TCON can someone check the vid?
                    Thanks in advance!...
                    09-19-2024, 10:50 AM
                  • rimwall
                    Sony KD-65x8500b - bad Tcon or panel?
                    by rimwall
                    Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                    a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                    b) the Tcon board is malfunctioning,...
                    10-24-2023, 07:58 PM
