Panasonic plasma th-42pz85b
  • vinceroger69
    • Mar 2012
    • 6714
    Hi guys just turned on my own tv was fine earlier and picture now messed up like this in the following pictures any idea what to check guys thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic plasma th-42pz85b
    Looking similar to the solarized picture you'd get with a bad T-CON Bd on a LCD TV. In the LCD TVs and I know this is a PLASMA TV in the service menu you would be able to access a setting called Option Byte and change the Panel code from a list. I'm not sure if this TV carries this option. I've never come across this before in my 15yrs of repairing plasmas. Could this have something to do with the SET-UP and SET DOWN adjustments on the SC Bd? Are your Vs, Vda, Vsc Ve voltages on spec or close enough?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      +1 Looks like the best starting point is check the voltages and see if one has gone awal.
      • vinceroger69
        • Mar 2012
        • 6714
        Ive just took the back of and cleaned the lead on the control board its looks like a lvds lead? i can only see the one end it was very loose in the connector so ive just sprayed with contact cleaner and air duster and reseated that connector end its now turned on fine pictures ok again so just testing it now, but maybe its the other end of that lead so may need to take out control board to find that end and clean it too.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Funny how that red lvds lead gets loose? Probably not seated correctly in the first place....
          This is a very well build tv that lasts a long time ( besides the 10uf cap )..
          • vinceroger69
            • Mar 2012
            • 6714
            Yes red lead i guess you have seen this before? is the other end easy to get too? and yes i got this set free in 2013 non working replaced the two 10uf caps been fine until today
            Edit! well ive just put the tv back together and will leave it on test but cleaning the control board end of that lead does seem too of fixed the issue.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Sometimes as professionals we tend to overlook the simple solutioins and dive headlong first into the technical stuff. Good Fix. Perhaps you could look at the other connectors too and clean and reseat them as well.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I wish all repairs were that simple
                • vinceroger69
                  • Mar 2012
                  • 6714
                  me too, it took me longer to remove all the screws than too clean the cable and re seat it, yes i maybe should of cleaned more connectors as andrew says, but whats thats saying, if its working leave it alone lol knowing my luck today something will break.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    No i have not seen that before but you got this tv for free because it was not working. The last owner probably removed the cables and not reseated the red cable correctly.
                    The small board is behind the mainboard but you need to remove just the screws from the mainboard housing.
                    It looks like this:
                    http://www.shopjimmy.com/panasonic-t...js-d-board.htm
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      It looks like this:
                      Thanks if it does play up again i will clean the other end of the cable touch wood it seems ok at the minute
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Just too update the thread the tv seems fine now no more messed up picture issues it must have been that loose/dirty lvds lead wish all repairs was this easy but hey makes a change from replacing failed leds on friends/customers tvs .
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Agreed..
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • Alicat
                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                            by Alicat
                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                            Model number is TH-50PZ85U
                            Power comes on and the red power light stays on solid.
                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                            I also hear a few clicks.
                            I also think my parents said there was a thunderstorm and the TV failed after that.
                            Section 6 in the service manual talks about power and no screen,...
                            10-30-2024, 10:09 AM
                          • Lintesir
                            Panasonic P42S30 Plasma - Pink sparkles
                            by Lintesir
                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                            There is about a 5cm high region at the top without any sparkles,...
                            07-26-2024, 03:16 AM
                          • badcappo
                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                            by badcappo
                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                            Diode type G972s6 - D101 with a short
                            Mosfet 06N90E - Q301 shorted
                            Fuse T5AH 250V - F103 blown
                            Diode D301 shorted
                            Relay DG1U-17VDC II - RL001 blown
                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                            11-24-2024, 11:27 AM
