Identification of Capacitor
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    I have 3 small blue disc capacitors that I need to replace. The only marking on them is the number 106. Any idea how to find replacements of these
  • R_J
    • Jun 2012
    • 9628
    Re: Identification of Capacitor
    106 = 10µf, now if we had a picture and where it is used....
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      http://www.kiloohm.info/3-digit-capacitor/106
      here is a calculator site you can use.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        It's used on a y main board. My phone won't let me attach the photo but here is a link to the caps I'm having issues with.
        https://m.youtube.com/watch?v=n6h7P-ZATnw
        • R_J
          • Jun 2012
          • 9628
          I can't be sure as I don't have that board but I would guess something like Ceramic 10µf 50volt. Maybe someone else has replaced them and knows what they are exactly.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Yea I don’t know how they expect someone to know what kind of cap this is with the only marking of 106 on it.
              What is the P/N of U5014?
              Those 3 caps (C5050, 5152, 5153) look to be connected in parallel and used as filter cap on the Cathode pin of the D5005, the Anode is connected to one of the Transformer T5000. That section looks to be SMPS, the IC U5014 is for driving the primary winding of T5000.
              Did you remove the 3 caps to check the capacitance?
              Is this your board: LJ92-01906A?
              http://www.shopjimmy.com/samsung-lj9...n-drive-1.htm#
              • R_J
                • Jun 2012
                • 9628
                I can't see the voltage being that high, maybe 25v cap wouldbe fine. They seem to be used as the filter caps for the voltage supplied by D5005, they seem to be in parallel for a total of 30µf. You should be able to measure the voltage and pick a cap that is higher.
                Poly caps at 10µf look quite large even at lower voltages
                Ceramic at 10µf look about the right size
                https://www.digikey.com/products/en/...=1&pageSize=25
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Replaced many of these 10 uf at 50 v ceramic
                  got mine from RS components
                  https://au.rs-online.com/web/p/ceram...itors/8118373/
                  • MORETTIGIAN
                    by MORETTIGIAN
                    Title:
                    Description:
                    Procedure performed:
                    - Removed backplate
                    - Reapplied thermal compound
                    - Reassembled card
                    09-18-2025, 12:14 PM
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                  • pcconnect
                    PS5 no power 5V short - capacitor identification
                    by pcconnect
                    Dead PS5 CFI-1216A, only 12v present on the board EDM-033
                    Blown capacitor which is located 'under' HDMI Decoder IC on the other side of the board. Does anyone know what is the value of the capacitor, please? Pics included.
                    Thank you...
                    08-11-2025, 09:39 AM
                  • eastcoastcomputing
                    Capacitor identification
                    by eastcoastcomputing
                    Hi there,
                    Beginner's question, sorry to waste your time...
                    I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
                    Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A...
                    06-04-2025, 05:15 AM
                  • slybunda
                    Gemcon capacitor replacements?
                    by slybunda
                    taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                    there are 2 caps which im looking to get replacements for.
                    Branded as Gemcon
                    single 100uf 16v 6.5mm x 11.5mm
                    single 100uf 50v 8mm x 11.5mm
                    lead spacing is around 3mm
                    there is space for 16mm tall caps
                    rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                    the caps have...
                    02-05-2024, 03:36 PM
