2011 Panasonic TC-P50S30 IS DEAD
  • notch8
    • Jul 2018
    • 63
    Hi all, just got this last week for free, original owner just said NOT WORKING.
    TV looks like new, remote even looks new. These are my results after reading/testing for 5 days:
    No led, ever
    No relay clicks, ever. All the fuses have continuity.
    By the guide, slide 33, I should replace the A board however I'm not convinced
    See attached pics, slides 24 & 25
    I've got STBY 4.94V @ P6Pin6, A6Pin6 & P34
    IMHO I need to get power to P6 Pin5 to close switch in IC5000 to supply power
    to A1 Pin3 to K1 Pin3 to LED, as per slides 24/25.
    Also, what does VCC mean? Slide 25 refers to the blue box on the P board as
    IC701 MCU. I can't find that on my P board. There's a Z701 chip near P34.
    I know this is probably an A board issue but I'm not ready to make that my final answer. If someone, TW2005 orTOM66, can shed some light on this problem I'd really appreciate it, thanks in advance, great site!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: 2011 Panasonic TC-P50S30 IS DEAD
    If you hear no 'clicks' when you plug-in and try to turn on then that would indicate a bad PSU or P-Bd. Disconnect the Vs connector (it may be P2) that goes to the V-Sus or SC Bd. Try to power on again and see if there are any clicks? No clicks mean bad PSU or P Bd.
    If you post clear focused pics of the underside of the PSU so I can identify the Connector pins and their labels, I may be able to advise you on doing a self-test.
    • notch8
      • Jul 2018
      • 63
      Thanks Andrew for the reply! I should have clarified, I have no relay clicks period. Using the tv on/off button or remote...nothing. Remote has good batteries, I checked. Already disconnected p2 to SC Bd & p11 to SS Bd, plugged power back up...no change, nothing, no clicks. Question: Is PSU and P-Bd the same thing? I hope so or I'm lost. I took some good pics of the topside connectors, which I'll post. Do you want pics from underside the board, the green side where all the solder lives? Again, thanks.
      • R_J
        • 9553
        I thought of checking R104, but it must be ok if you have standby voltage. Have you checked all the fuses on the power supply board?
        • notch8
          • Jul 2018
          • 63
          Thanks RJ
          All fuses, F101, F102, F201, F301, F401 all check good for continuity. F401, the white ceramic part of the fuse is not as white as the rest. The rest look brand new, 401 is just a little very light grey but continuity checks good...0.00 ohms.
          I'll look for and check R104, thanks.
          • R_J
            • 9553
            R 104 is the white ceramic resistor near the relays, But like I said it is likely ok. F401 is the fuse for the standby voltage, since standby is on 24/7 the fuse may be slightly discolored, nothing to be concered about
            It is possible the main (A) board has a problem and not providing the power on comand
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes the PSU (Power Supply Unit) and the P-Bd. are the same. (Sorry if I confused you).
              OK. So to self-test the P-Bd. you need to make a test-lamp to act as a load for the P-Bd. by taking two (2) 60-100W 120Vac incandescent household bulbs and connect them in series. You would also need three (3) 100ohm resistors.
              1. Disconnect all connectors from the P-Bd, leaving the P9-ac connector.
              2. On connector P6 connect solder one end of a 100ohm resistor across pin 6: StBy5V and pin 7: F-Stby-ON.
              3. Take a 2nd 100ohm resistor and connect it across pin 6: StBy5V and pin 1: Panel-Main-ON.
              4. Take a 3rd 100ohm resistor and connect it across pin 6: StBy5V and pin 5: StBy5V-ON.
              5. On connector P2, connect your test-lamp across pin 1: Vsus and pin 2: GND.
              6. Re-examine your connections to verify they are secure and clean, not shorting on anything or touching anything it is not supposed to touch.
              7. Plug in the ac.
              If the P-Bd. is good the test-lamp should come on and light bright. Test P35 for Vda and the other pins on P6 for 15V etc.
              If test-lamp does not come on and you are sure everything is connected and isolated as described then the PSU is dead.
              • notch8
                • Jul 2018
                • 63
                Checking r104: see pic, the end with 2 pins (we'll call a& b and the other end c)
                testing: a-b =10 ohms, a-c=0 ohms, b-c=10 ohms. Does this sound right? Is the resistor ok or bad? It looks new, no discoloration, thanks.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  10ohms so that is good. What 3rd pin are you speaking about? I can only see tw0 (@) pins as any normal resistor would have.
                  • notch8
                    • Jul 2018
                    • 63
                    7. Plug in the ac.
                    Andrew....THANK YOU for all of this info/help. I'll get to work on it asap and report back. I'll have to scrounge up the parts. This tv is way too nice to give up on, fingers crossed.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Mind you, I think your P-Bd. is bad. No clicks.
                      • notch8
                        • Jul 2018
                        • 63
                        Here are some more pics, I see 3 pins, IDK, I'm a noobie on electronics, maybe you can straighten me out, thanks!
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Ahh, I see!!...The third pin is not connected to anything and is just an anchor pin to hold the resistor down on the PCB. So you were right 3 pins.
                          • notch8
                            • Jul 2018
                            • 63
                            Is there no way to find the failed component/components and repair? Is a new P board the only answer?
                            • notch8
                              • Jul 2018
                              • 63
                              I thought as much also but unsure, thanks.
                              • notch8
                                • Jul 2018
                                • 63
                                7. Plug in the ac.
                                Did the self test today, hooray, relays clicked , light bulbs lit, checked and had 12vdc on P6 pins 10 11 13 and 15. I'm not sure which pin to check on p35 for Vda and what voltages to expect. Thanks
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Right so the P-Bd is OK. To measure Vda on P35 look at the connector cables and see which two are used. I can't remember off-hand. If no measure across pin 1-GND and pin 4-Vda. May be around 55~60V. Look at the Panel sticker or on the back cover for a voltage table. Good job with the testing. Let me know what you get with Vda. We have more testing to do, but I suspect the A-Bd though.
                                  • notch8
                                    • Jul 2018
                                    • 63
                                    Thanks for the likes on the testing but I don't deserve it. While checking for 15vdc on the connector side of P6 (dumb on my part) I bumped my big probes together and burned #10 pin into. Spent half the afternoon replacing it with a spare. Thank goodness for spares. The repair came out good. Anyway, while I was at it I reflowed Z701 & P34. I put the board back in the tv, plugged it in no change, still dead. 4.94v @ P6 a6 & P34. I'm posting a pic of P35, 1 is Vda and 4 is GND. Can I do the test with the board hooked up in the tv like it is now or do I have to reconnect resistors, lights again? I suspect A board failure also. I think IC 5000 is bad, thanks, Roger
                                    • notch8
                                      • Jul 2018
                                      • 63
                                      I still feel like A board fault is problem, IC 5000. Even if I replace IC or the A board, if there's a fault on down the line, the new part will fail also and I'll be right back where I started. Starting to feel overwhelmed, especially after reading this 2013 post of a similar problem plus the flowchart advice, see pics. I'd like to be able to fix this tv but new ones are getting cheaper everyday so I can't justify putting much into it.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        The A-Bd sends out the TV-SUB-ON signal to the P-Bd to generate the F15V which causes the relays to 'click' and the 15V goes to the A-Bd. to produce SUB5V, SUB1.8V and SUB1.2V to power various circuits in the A-Bd. So as long as the TV-SUB-ON signal does not go to the P-Bd. the set will be dead. Again this points to an A-Bd. problem and as you said it may be easier to just look for a replacement board rather than try to replce the IC on the A-Bd that generate the TV-SUB-ON signal.
                                        • Rensiee
                                          Panasonic TH-50PX8EA Black screen, only relay clicks
                                          by Rensiee
                                          I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                          I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                          When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                          I have measured the voltage in the VSUS line, which...
                                          06-18-2024, 12:58 PM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
                                        • badcappo
                                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                                          by badcappo
                                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                          Diode type G972s6 - D101 with a short
                                          Mosfet 06N90E - Q301 shorted
                                          Fuse T5AH 250V - F103 blown
                                          Diode D301 shorted
                                          Relay DG1U-17VDC II - RL001 blown
                                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                          11-24-2024, 11:27 AM
                                        • mostachio
                                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                          by mostachio
                                          Hi Badcaps,
                                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                          TV Details:
                                          Model # - TH-65DX700Z
                                          Symptoms:
                                          The television turns on and displays a picture then makes a clicking sound and turns off.
                                          I haven't opened it up yet but...
                                          09-04-2024, 02:32 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
