Samsung PN50A450P1D - Distorted Pink/Orange Picture after loud pop
  • m_guimont323
    • Jun 2018
    • 9
    Hey guys !
    New around here, tried a bit of diag on my own before venturing here, but have not had any luck so far. Hoping someone can shed some insight as to whether or not this TV is a lost cause or not.
    TV is a PN50A450P1D Samsung Plasma
    Symptoms:
    Powered on the TV after it sat for a couple of weeks, after the boot tone heard a loud pop. When the TV booted, the screen picture was as seen in the photos below. This is with my PS4 hooked up, same type of picture presents itself with all inputs and menus.
    I ran the pictures tests by disconnecting the logic board main cable and jumping pins 3&4, screen briefly powered on displaying the same distorted pink/orange picture and then shut down immediately on its own.
    Found a popped cap on the power supply board. Replaced this cap to no avail, same picture.
    Assumed it was an X-Main board failure and ordered a tested replacement with the following specs to match the unit I had installed.
    Model no: 50" HD W3 X-Main (1L)
    PCB NO: LJ41-05307A
    REV NO: R2.5 (07/12/15)
    PBA NO: LJ92-0151A/B/C/D
    Finally booted up the TV again today to see no change. Looking to either confirm this is an X-Main failure (perhaps I was sold a faulty unit), or perhaps this TV is a lost cause.
    Any insight is greatly appreciated !
    Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
    This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
    09-06-2024, 09:30 PM
  • serious_electron
    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
    by serious_electron
    Hello Everyone!
    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
    06-28-2025, 02:57 PM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
  • maleksa
    Yamaha MOX8 boot freeze and distorted sound
    by maleksa
    My Yamaha MOX8 synthesizer recently developed two issues.
    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
    11-07-2024, 03:28 AM
  • mosfetratus
    macbook A2918, orange light off when shut off
    by mosfetratus
    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
    Works with battery and charges, but when i shut off i get this problem.
    It had liquid spill. Board has no corrosion, keyboard is working, power button...
    05-31-2024, 03:34 AM
