LG 42LA620V another problem now
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Hi, I have an LG 42LA620V had a backlight issue, when powered on the logo flashed up briefly then screen goes off, sound present. So replaced the LED strips at fault, backlights come on as they should, so put it all back together, and now it has another fault! When turn it on now screen lights up but ..... pics attached
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42LA620V another problem now
    Have you put the various panel layers back in the correct order and way round?
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Theyre deffinately in the correct order, as I taped the corners together before lifting them out, however they were out a while so I wonder if they the right way round now lol, the thickest rigid one is on the bottom if I remember correctly
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        The pictures look like backlight LED failure but you did change them all out right? Check the sheeting again
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          when you change inputs, volume, channel, menu etc. does the image change quickly, crisply. ignoring the colour issue that is.
          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Theres pic of backlights without the screen in
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              Ive done a factory reset to see if that would rectify, so only screen that comes up is the 1st setup screen, I cant change between inputs
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                interesting. since you have no inputs, the main board would most likely be the issue.
                i was actually concerned as to if you may of damaged the panel during your previous repair attempt. hoping it isn't multiple issues.
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  I probably can select inputs if I go through the setup, ill have a look when im home later, taking an engine out of an Insignia atm :/
                  • MrMagoo
                    • Jun 2015
                    • 6
                    • Oztrailya
                    tcon board? it looks like a pattern overlaying the signal Ive seen that on a few samsungs. do the dark patches expand and move or is that a photo artefact.
                      https://www.badcaps.net/forum/attach...0&d=1530822670
                      It looks like damaged panel.
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Its hard to show exactly what its like with pics, is there anyway I can upload a video?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Upload to Youtube and give the link here.
                          • Diah
                            • Feb 2013
                            • 6565
                            one time friend of me tried to change defect LED on same brand 55LA6208, before he replace the LED he told that LG Logo flashing at first start complete with color too, and after he replaced was the issue much like to you.. the first things i went to check for him the ribbon cable, and exact was one the pins Brocken and make short contact. this old TV because of heat the ribbon cable pins easy getting out from its place. also check them under magnifier from both sides
                            • theone111
                              by theone111
                              3. Problem: TV shuts down
                              07-22-2024, 10:36 AM
                            • Krisby
                              Protek 506 DMM Problem/Fault
                              by Krisby
                              Hello badcaps.net Forum People,
                              I have a Protek 506 DMM which has a problem with the Diode Test Function and with the 4V range of the Voltage Measuring Function. I have posted this on three other forums, but have not been able to find out the source of the problem.
                              It seems that the Diode Test problem is linked with the 4V range Voltage Measuring problem, so I shall just focus on the 4VDC range to simplify things.
                              When I select the DC voltage function on the rotary switch of this DMM, the display alternates between showing 3.999V and 0V. If I test a...
                              10-14-2020, 06:26 PM
                            • Zeonalbasta
                              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                              by Zeonalbasta
                              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                              09-13-2024, 01:17 PM
                            • Gibon378
                              Problem with stopping audio and video for no reason
                              by Gibon378
                              PC Specs:
                              • CPU: Ryzen 5 1600
                              • GPU: GTX 1080 Palit JetStream
                              • MOBO: ASRock ab350 PRO4
                              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                              • PSU: XFX 650W (don't remember what model)
                              • OS SSD: ADATA SP920
                              • OS: Windows 10 21H2
                              Problem description:
                              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                              11-19-2022, 09:41 AM
                            • perzyk23
                              Lenovo T580 - LCD Panel problem - error 0288
                              by perzyk23
                              Good morning,
                              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                              10-25-2024, 12:42 AM
