LG 49LB5550-UY with backlights that flicker on and off
  • SdlewisSr
    • Oct 2015
    • 146
    I have an LG 49LB5550-UY with backlights that flicker on and off. Other than that everything works.
    I checked the voltages on P201 of the PSU (leading to mainboard) and all are as supposed to be.
    P801 (leading to the LED strips) has fluctuating voltages with LED strips connected and disconnected.
    LED+ on one side fluctuates from 123v to 126v when connected and from 174v to 194v when disconnected.
    LED+ on other side fluctuates from 128v to 145v when connected and from 135v to 148v when disconnected.
    Since the voltage fluctuate with the LED's disconnect I suspect a problem with the LED driver section.
    I do not see any visual signs of failing components. I was wondering if anyone has seen this behavior before or has the service manual.
    I am including an animated GIF of the flickering and image of the PSB/LED Driver.
    Thanks in advance for any help/support.
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 49LB5550-UY with backlights that flicker on and off
    Did you try turning down your backlight level?
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      are you measuring each pin in reference to chassis ground.
      led+ =....v
      led- =....v
      led+ =....v
      led- =....v
      each pin with all cables attached.
      on power up, measure spike and then what the voltage settles to?
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • SdlewisSr
        • Oct 2015
        • 146
        (I used underscores _ to help with alignment of the text below)
        I do not have the remote to lower the backlight level.
        I measured from chassis ground
        ____________________LED+________LED-________LED+________LED-
        Power up high voltage__:155v ________31v_________145v_________83v
        Fluctuating low _______:123v-126v____19v-21v _____128v-145v____70v-80v
        I then measured the fluctuating volts on each while the TV ran with flickering.
        _______LED+______LED-_____LED+______LED-
        HIGH__136.9v_____34.6v_____146.2v_____81.5v
        LOW __121v_______18.9v_____130.8v_____65.5v
        I reversed the LED strings and still get the same flickering. I disconnected only one string and still got flickering. I disconnected the other and still got flickering. I put reversed the strings, with only one string at a time connected, and still got flickering.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          your led- voltages look way too high. i believe that you have shorted led's in the panel.
          this is where an led tester comes in handy.
          let's see if others come to the same conclusion.
          • SdlewisSr
            • Oct 2015
            • 146
            My next step was going to take the panel apart and check the LED's. I did not even consider a backlight tester. Thanks attainteddragon. I just ordered one and will have it Thursday.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Is the DC voltage across the two legs of C610 holding steady or is this fluctuating and causing your backlight problem.
              • SdlewisSr
                • Oct 2015
                • 146
                C610 is holding steady at 400 V.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I would have expected the voltage at the led connector to be steady at some value when the led's are disconnected. I see there are 4 electrolytic capacitors around the connector. Have you checked them for value and ESR readings.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    This is atypical case of bad LED backlights. Perform the checks dick barton recommends. Be prepared to tear down the Panel to get to the LEDs. Being a 49 incher be careful when handling as the break very easy. If you want along tem fix, change all the strips even those that appear to be OK. They will fail in the short term and you will have to rip her open again.
                      https://www.badcaps.net/forum/attach...4&d=1530592637
                      If you look at the Voltage chart as printed on the board, you will see the TWO output Voltages for the two LED strings which are not the same, one LED string has more LED than the other string. The loaded Voltage for the smaller string is 113V 205mA, the larger LED string is 170V 205mA.
                      How steady are the Dimming control Voltages?
                      The two 47uF 160vdc caps (C223?, 224) are for the filter caps power supply that feeds the two Boost converter circuits, so you need to check the Voltage between the two legs of those two caps to see if they are steady or not.
                      • SdlewisSr
                        • Oct 2015
                        • 146
                        I appreciate all the input. I have a new development in this mystery. When I removed the PSB to check the caps, I discovered corrosion (see pics). Also the screws that secure the PSB in place were not tight. I am going to attempt to clean the corrosion and determine if any of the traces, solder joints, or components are damaged before proceeding. Probably will half to just replace the PSB.
                        Thanks again for all the support
                          All the through holes solder rivets should be inspected closely for cracked/poor solder joints.
                          • Diah
                            • Feb 2013
                            • 6435
                            Originally posted by andrew f. Ali
                            this is atypical case of bad led backlights. Perform the checks dick barton recommends. Be prepared to tear down the panel to get to the leds. Being a 49 incher be careful when handling as the break very easy. If you want along tem fix, change all the strips even those that appear to be ok. They will fail in the short term and you will have to rip her open again.
                            +1
                            • SdlewisSr
                              • Oct 2015
                              • 146
                              ESR values (out of circuit)
                              C801 2.1ohm
                              C805 1.9ohm
                              C224 1.8ohm
                              c219 1.6ohm
                              • SdlewisSr
                                • Oct 2015
                                • 146
                                Dim 1: 2.739v to 2.78v
                                Dim 2: 2.4v to 2.78v
                                Voltages across capacitors LED's not connected
                                ______High_____Low
                                C801__178.24v__163.52v
                                C805__147.37v__136.68v
                                C224__93.47v___90.15v
                                C219__93.42v___89.86v
                                Voltages across capacitors LED's connected
                                ______High_____Low
                                C801__130.61v__121.55v
                                C805__145.98v__128.41v
                                C224__92.76v___90.3v
                                C219__92.38v___89.7v
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  C801 2.1ohm
                                  C805 1.9ohm
                                  C224 1.8ohm
                                  c219 1.6ohm
                                  You don's give the value of the capacitors and I can't make out from the photo which one is which. Find attached a chart which is a guide for expected ESR
                                  • SdlewisSr
                                    • Oct 2015
                                    • 146
                                    ESR values
                                    C801 2.1ohm (Top Left) 33uf 350v
                                    C805 1.9ohm (Top Right) 33uf 200v
                                    C224 1.8ohm (Bottom Left) 47uf 160v
                                    C219 1.6ohm (Bottom Right) 47uf 160v
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      The 47uF, 160V should have a maximum ESR of around 0.46 ohms. Your readings are considerably higher.
                                      The 33uF, 200V approximately 1 ohm max
                                      Not certain of what the 33uF 350V would be but I suspect around 2 ohms.
                                      Have you also checked their capacitance and do they match what is on them.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        Those caps should be replaced. Is the BL-ON signal stedy when the Backlights are flashing? I still suspect bad LED backlight strips.
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • pb1911nt
                                          MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                                          by pb1911nt
                                          Hello forum,
                                          I'm still relatively new to the world of electrical repairs.
                                          I have a Macbook here that I can't figure out
                                          When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                                          I removed the logic board and took a few measurements.
                                          But I can't really figure it out.
                                          At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                                          09-07-2025, 11:35 AM
                                        • jesterace
                                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                          by jesterace
                                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                          However, I am in a dilemma.
                                          I tested the backlight outputs with the lights disconnected...
                                          10-20-2024, 10:15 AM
                                        • htv239
                                          LG UH8500 Backlight Troubleshooting Help
                                          by htv239
                                          I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                          Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                          What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                          10-11-2021, 01:53 PM
                                        • Storyteller12
                                          Vizio M801D-A3 backlights flicker
                                          by Storyteller12
                                          Need a little help here.
                                          the backlights flicker when watching tv. Everything else works as it should. Also it's not the picture that's flickering just the leds.
                                          I tested the leds and all light up and measure 77.5v volts. I took the tv apart to double check leds and they all work and light up perfectly.
                                          I believe it's the power board causing the issue however I cannot find a replacement board so I'm stuck to finding the bad component. The power board has a sizzling sound coming from the backlight transformer. I replaced that and problem persist....
                                          05-25-2021, 11:17 AM
