Hello everyone. The tv wont turn on. It got a red standby light that blinks as when pushing power on button. The tv has been laying for about 1 year now but what happened was that i was plugging i an antennea cable or maybe vga(cant remember which one it was ) and it just died instantly. Attaching pictures of the tv and the boards. I alson took some voltage readings as in one of the attached images. Someone who can point me in the right direction on repairing it? And btw, the readings i got was when plugging the powercord in and measured it in standby mode.
LG 55LM620T-ZE Not turning on
Tags: None
Re: LG 55LM620T-ZE Not turning on
do you have a couple of 1k resistors to jump the ps on?Last edited by attainteddragon; 06-30-2018, 07:24 AM.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS? -
All the secondary voltages appear to be up and running but you don't give the voltages for DRV_ON or ERROR.Last edited by dick_barton; 06-30-2018, 08:56 AM.Willing to help but I'm no expert.Comment
I saw now in my first that i wrote what could be misunderstood. To clarify, when I plug the cord in the red light goes on and stays like that until i press the power button, then it starts blinking and keeps doing that for a while before it goeas back to a static light. Some additional info is that i have a green led on the powerboard that after the tvhave been connected for about 30 secs start to blink. Blinks 5 times pauses and then 5 times again and keeps going like that.Comment
I noticed that on the pin labelled N.C (Not Connected) you have 12V. That is not right. I think there is an error in your readings Perhaps you could label the pins as pin1 ERR 12 V, pin 2 PS-ON 3.5V just as an example.Comment
DRV_ON is missing and should be around 3V to activate the backlight led circuitry. It's a signal from the mainboard so you may have a led fault giving an Error response turning off the DRV_ON signal.
Can you check what voltage is at PWR_ON when in standby and when you switch it out of standby. Some PWR_ON need to the voltage on the pin to go low to come out of standby and some need to go high to come out of standby.Last edited by dick_barton; 06-30-2018, 09:31 AM.Willing to help but I'm no expert.Comment
On the N.C pin i have nothing. The text inside the box labeled CONNECTOR is taken from board. To the left inside the box there are (at least how I think it is) the suggested values for the left column of pins and the ones to the right are for the right column of pins. The numbers underthe label READINGS are my measurements of respective pin in each column.Comment
Can you check what voltage is at PWR_ON when in standby and when you switch it out of standby. Some PWR_ON need to the voltage on the pin to go low to come out of standby and some need to go high to come out of standby.Comment
can you disconnect the loom that goes from the p/s to the main and measure what the ps/on pin reads. this will let us know if it requires a high or low voltage control to turn on.
your current measurement is what i would call neither, so need to confirm this.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
https://www.badcaps.net/forum/attach...9&d=1530363633
Based on what you show, the PWR_ON is fine otherwise not ALL the switched power supplies will be putting out. You can easily verify if the PWR_ON is OK or not by checking the DCV right between the two legs of the main filter cap, if you have close to 400VDC then the PWR_ON signal is OK otherwise you will not have PFC Boosted Voltage on the main filter cap. The PWR_ON may be stuck ON at this point if it does not toggle to 0V (= off). Some power supply boards do use <1V = ON, 0V = OFF instead of typical 2 ~5 V = ON, <1V = OFF.
You do not have Dimming control on one of the pin but not at the other P-DIM pin? Backlights ON signal is not present.Last edited by budm; 06-30-2018, 08:23 PM.Never stop learning
Do you mean the connector that i measured on on so far(P201)? If so it gives me 0V when disconnected.Comment
You do not have Dimming control on one of the pin but not at the other P-DIM pin? Backlights ON signal is not present.Comment
disconnect the main from the p/s and check them again.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
ok, so your main is stuck on. i'm not sure if you can get an eeprom for this board, or you would be looking at a replacement.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
So getting a new mainboard (and just to be sure, that is the one to the right in the photos of my tv?) would probably be easiest soultion?Comment
Assuming...7 Photos -
by chaos-theoryI have a card that does post at all, the owner said it does go into windows but it gets stuck on the logo with artifacts, I have no idea if he is lying or not... I tried the card on my pc and it does not post at, no beeps, no bios nothing just all fans turning and nothing else. I tried plugging DVI or hdmi but nothing, I tried unplugging the 8 pin plug from the power supply and it's the same thing.
I just want it to post and get into the bios at least.
Forgive me if I am wrong, but I tested the 3 PCIe 12v power pins on the left(550ohm) and the 4th one from the right 3.3v (400ohm),... -
by SparklingxHP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
by khelaneHello
A device with specifications
Toshiba Satellite PRO A50-A is here to replace the hard drive.
The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off.... -
by RabitRecently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
This can be signs of bad capacitors causing overheating PSU ?-
- Loading...
