Samsung UE46D5500 keeps rebooting
  • lipo
    • Jun 2018
    • 10
    • Czech Republic
    Hi, my Samsung UE46D5500 hate me.. so after some random reboots stucked in aprox. 20sec reboot loop.. (Black screen ->status led blink-> samsung logo-> black screen)
    video: https://unsja-my.sharepoint.com/:v:/...gMwWA?e=FjQDe7
    (sry ist too big, for forum upload)
    model: UE46D5500RW
    model code: UE46D5500RWXXH
    Version No: 01
    S/N: Z8D93SPBB01273D
    already done:
    - unplug from el. for couple of days
    - unplugged LAN, blinded IR
    - mesured all capacitors on power board(ESR, capacity at 120Hz,) all sems ok, visualy OK but it was measured in circuit..
    -measured all signals at connector from power board (13V, 5V etc..) all seems ok, but im not sure how they are related to each other, some help will be appreciated...
    - forcing Power on/off signal to 1(3V, 5V, 10V, GND), without success->still rebooting
    i found:
    - when i unplug "logic" board and turn Tv on backlight stay on without rebooting
    - just dummy load + backlight -> power board, unpluged logic board -> without reboots
    - status, standby leds works normal, responding to the buttons..
    - backlight dimming works (after power on its on full, then goes to minimum, PWM signal on PWM_DIM pin is OK)
    conclusion:
    after 2 days figuring out the problem im out of ideas..
    maybe some info about connector CNM803 and all signal will little bit help..
    schematic included, but i dont fully understand it..
    any ideas?
    im little bit scared there is problem in "logic board" --> new Tv
    ps: sorry for my english
  • DIMITRIO
    • Jul 2017
    • 9
    • GREECE
    Re: Samsung UE46D5500 keeps rebooting
    Bad blocks in nand flash memory.new nand with new bin file
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      you seem to be on a good way, as you already tested the power supply board.
      Not much here left to do, as DIMITRIO said, new nand flash with good firmware. Do you have a programmer that can handle such job?
      Also, before this, I would try to make a software update via USB. With the set turned off. Maybe this could help.
      Cheers, Janos
      • lipo
        • Jun 2018
        • 10
        • Czech Republic
        thanks for reply, ideas.. looks like there was one more guy with same problem ->
        https://www.elektroda.pl/rtvforum/topic3225022.html
        looks promising
        is there any way to get new bin?
        is it read protected? sometimes just write doesnt work, so it can by possible to read it..
        i found preprogrammed nands on ebay but they are little bit too expensive(about 100€).. so it will be last chance..
        or is there someone who doing this for better price?
        tomorrow ill borrow programmer and try to read it..
        and how to "software update via USB. With the set turned off" ?
        i found just "online" methods..
        • yohnsee
          Semi-noob
          • Dec 2017
          • 198
          • Hungary
          I was thinking to download the bin file for the eprom, copy it on a flash drive, plug the TV out from mains, plug in USB drive then plug tv back in mains. It should update its own firmware, without turning on the set. Thumb drive must be FAT32 formatted. Altough I am not 100% sure, that Samsung sets do this kind of update, but may worth a shot, before you have to go inside and desolder and reprogram components.
          EDIT: On this site, if you scroll down, you will find a downloadable .exe file.
          https://www.samsung.com/uk/support/model/UE46D5500RWXXH
          I would first try the versoin 1025. Some articles report the newer one to be buggy.
          This exe file should make you a usb updater thumb drive.
          As I read along, it looks like you must turn the set on, to start the update. All the above steps remain the same (unplug- usb in then reconnect to mains)
          Cheers, Janos
          • lipo
            • Jun 2018
            • 10
            • Czech Republic
            doesnt work.. no firmware update will happen, just rebooting..
            -FAT32, tried in both USB ports..
            all guide for samsung & USB firmware update was through menu-> software update -> by usb.. but i cant get there..
            • yohnsee
              Semi-noob
              • Dec 2017
              • 198
              • Hungary
              Then back to the beginning. As DIMITRIO said, get your hands on a programmer, a new flash IC and search for the contents on the internet.
              Cheers, Janos
              • lipo
                • Jun 2018
                • 10
                • Czech Republic
                yep, worst part will be to find proper firmware..
                edit: just found that programmer i can get doesnt support this type of memory.. so i have to buy preprogrammed IC..
                but randomly found guy in Czech Rep. who selling it.. unfortunately he is on vacation until 8.7.
                • lipo
                  • Jun 2018
                  • 10
                  • Czech Republic
                  so after all I found guy from Slovakia who tell me that there is no need of new memory.. just need to reprogram the current one so i paid 20€ inc. shipping for reprograming..(desoldered sent to him and soldered back) and Tv is working..
                  thanks a lot for help!
                  • junkpete
                    • Jun 2018
                    • 14
                    Seems like I have a similar issue (I just started another thread). @lipo would it be possible to ask the guy if he could do it for my set too?
                    • lipo
                      • Jun 2018
                      • 10
                      • Czech Republic
                      contact send via PM..
                      • ohren
                        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                        by ohren
                        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                        The models launched in 2018 and 2019 respectively....
                        09-08-2023, 05:24 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • C152Heavy
                        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                        by C152Heavy
                        Summary for TL-DR readers:
                        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                        • Have obtained Samsung schematic & service documents - Can upload if helpful.
                        • Have read ALL applicable threads
                        • C1818 and CP820 replaced as low hanging fruit
                        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • Yanleb
                        LG 60PK550 Logic Control Board EBR63450301
                        by Yanleb
                        Hi all, I just want to share the repair of my 60PK550-UA TV set.
                        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                        C57: 3.30V
                        C61:...
                        07-20-2023, 12:38 AM
