Teac lcd2681fhdr, no stby
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    SOME HISTORY ON THIS ONE (rather boring, skip to the entertaining part)
    i got this one from another repairer that told me that he changed out ds3 (shottky diode on the secondary side). he applied power and said that it instantly took the diode out again. i found that the diode is ok and assume that he must of been having a late night and was probably delirious from tiredness. the only thing is that he replaced it with a matching spec of diode.
    MY FINDINGS
    there is no power on the secondary side of the p/s and have the unit on the bench.
    this p/s is starting to look worse for wear as between both of us, we have removed a large chunk of this p/s trying to find the problem.
    i have not been able to find a schematic.
    p/n- LK-P1260412A made by leke
    pcb no- CQC09001033440
    i have 322v on the main filter cap (so pfc is there, just not boosted yet)
    the 322v shows up on the 2 right hand pins on the transformer (as you look at it from the bottom), and the direct associated components.
    i only have mvs on the start up cap (has been esr and capacitance tested)
    i am unsure how the stby is derived from primary to secondary on this board. teach on this one. i'm used to a separate stby transformer.
    i started looking at the stby ic (u102)
    struggled to make out much of the info on it, so no data sheet.
    but it looks like
    top line (missing text)TBAAA
    second line 753
    third line mya
    readings from this ic
    pin
    1- 58mv
    2- 96mv
    3- 0
    4- 0
    5- 0.08mv
    6- 0.05mv
    7- nc
    8- 303v
    i have been staring at this chip thinking that there must be a signalling voltage, but without a datasheet, i personally would just be guessing.
    i'm sure someone will point out something that i should know.
    thanks for reading my novel, hope i don't end up releasing a part 2.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Teac lcd2681fhdr, no stby
    This is an always ON PSU, so I don't think you would see a StdBy 5V, per say.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      if it is meant to be always on, it still has the issue with, well, not being on.
      i have been searching through my spares to try and find a similar board to compare with,
      as i know there a few variations of this board. but no luck yet.
      i will also have to see if i can find a schematic from one of the other variants.
      • R_J
        • 9581
        Try cleaning the top of the ic with alcohol It may show the numbers better. It might be a fan6753 ?????
        Try replacing C132
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          yeah, tried some iso then resorted to rubbing a tiny bit of thermal paste on it to highlight it a bit. i will try to see if i can get a pic of it with a different camera. my cannon doesn't do macro very well with the lens that i have.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            c132 was the one that i have already tested. blonde moment, didn't actually write down the location designator.
            i think that you are right about it being a 6753. looking at the datasheet,
            pin 5 and 6 have a low resistance to ground, so i will have to most likely order one.
            i don't think that i have any laying around.
            i'll update when i have it in.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              pics i got of the pfc ic.
              • R_J
                • 9581
                If pin 6 is low Ω to ground, check for a shorted diode (d107?) next to J53 jumper.
                If pin 5 is low Ω to ground also check for shorted fet.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  D107 is good
                  lifted the fan chip and my low resistance on both pins is gone.
                  feeling confident on that chip being bad.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Yes it does appear to be the culprit here.
                      Acer Aspire A515-55-322V Notebook 5 Specification for Upgrade or Repair
                      This specification for the Acer Aspire A515-55-322V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-55-322V boardview and A515-55-322V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 10:50 PM
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • NicRac
                      monowheel repair,Is the diode the problem?
                      by NicRac
                      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                      First of all, I am new here. Therefore I will shortly introduce myself.
                      I am Nico and currently I study Physics.
                      In my freetime I like to build and repair stuff. Especially big battery's.
                      A few years ago I got myself an electric unicycle, monowheel or however you call that.
                      The battery bms was broken so I replaced and resolder that. Nothing big.
                      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                      07-26-2024, 06:13 AM
                    • dennis_elx33
                      NO BODY MARKING Diode
                      by dennis_elx33
                      Hello Everyone,
                      I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                      While compared to the reading of another diode from the next channel it won't read at reverse bias.
                      Now the problem is; it does not have any body marking.
                      So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                      What do you think is this diode?
                      Can you please suggest what part number can i use to replace this faulty diode instead?
                      Hoping that you...
                      06-14-2024, 12:36 AM
