Sony KDL-40W600B 6 blinking lights
  • loukastx
    • Jun 2018
    • 9
    Re: Sony KDL-40W600B 6 blinking lights
    " Sometimes, it will power down after a few minutes, and yet other times, it'll stay on for hours." Seems like a bad/weak capacitor.
    Possibly. Some more data: sometimes, just a split second before it turns off, the picture becomes suddenly dimmer, and then it turns off. Also, I had it set to "vivid" mode, which had the brightness set at max: it couldn't sustain it, and it would shutdown with the 6 blinks. Then, I set the picture to "standard", and it was able to stay on longer (initially for hours, then for only minutes).
    Does this strengthen the bad capacitor argument? Will it be on the BAXL? Because the LD board, which drives the LEDs, was changed, and the problem didn't go away? Or could it also be a led problem?
    • budwich
      • Jul 2015
      • 3097
      it is more likely that you have a "weaken led" as opposed to a "driving capacitor issue"... the "overdriven led" is eventually drawing more power causing protection to kick in.
      • loukastx
        • Jun 2018
        • 9
        Originally posted by yohnsee
        While in service menu, can you get enough time to enter the error code list? I believe, sonys has that. Maybe that would give us some useful information, before we go in and test everything.
        I don't know, if anyone has suggested yet, try to cool specific parts of the TV and see if it stays on longer. For example, first the TCON, then make a test. Then the mainboard, then test again. This is carried out the easiest way if you have canned air at home, turn it upside down and spray on the board from 15-20cm. It will cool it down very quickly. After these tests we can move on with other ideas.
        R_J: With all due respect, as OP said in the first or second comment, he has picture and sound, so the TV works good for a short period of time. This should not be a cable connection problem.
        yohnsee:
        whenever I was able to get to the service menu, the only errors show up under 006 BACKLIGHT, with a counter equal to the number of times the error came up (47 the last time I checked). There are also numbers indicating the exact time and date of the last 3 backlight errors.
        There is no TCON board I can readily access in this TV.
        • R_J
          • 9518
          There are at least two seperate strings of leds and each string seems to have 5 led strips, if one of the strips has a loose connection it will not stay lit. and post an error.
          • Rvang
            • Jun 2018
            • 11
            • Rvang
              • Jun 2018
              • 11
              Originally posted by R_J
              That picture I posted was from shopjimmy, his may have looked like this
              Yes, That's it, exactly
              • Rvang
                • Jun 2018
                • 11
                So Far so good.....
                • Rvang
                  • Jun 2018
                  • 11
                  Why would Sony disable the whole damn tv for a bad LED. Coudln't they just flash an error?
                  • R_J
                    • 9518
                    Likely worried about this, and I have seen a lot worse, I've seen the white reflector sheet with a 4 inch strip burnt into it
                    • Rvang
                      • Jun 2018
                      • 11
                      Ahh, I see, Makes sense
                      • Rvang
                        • Jun 2018
                        • 11
                        Well this is day 3 without any problems. The set would flash a 6 almost instantly before.
                        I think the cause was related to poor contacts causing high resistance in the LED circuits.
                        I would assume the system monitors the load on the LED circuits and faults out if it exceeds the set range /window.
                        Again, All I did was disassemble all the LED connections and re seat them multiple times.
                        I have seen this happen in automotive Air bag systems. They monitor the resistance of the air bag to a very narrow range. Any resistance introduce into the circuit and it faults out.
                        • budwich
                          • Jul 2015
                          • 3097
                          Perhaps.... but didn't you also indicate that you change some settings?
                          • Rvang
                            • Jun 2018
                            • 11
                            No, I changed the BAXL and HDLM on a hip shot and it didn't work, did the same thing. I then whacked the upper corners of the set and it started working. That prompted me to take it apart down to the LED Strips and have a look see.
                            • loukastx
                              • Jun 2018
                              • 9
                              Well, this was indeed the case: one of the B strips had 2 burned LEDs (out of the 5). I replaced the LED strip today, and so far so good.
                              I thank you all for taking the time to answer. You really helped me narrow down the problem and eventually fix it.
                              Best
                              • davemc
                                • Aug 2013
                                I have a Sony KDL-40W600B that was blinking 6 times and ordered a replacement LD board... When installed the set would come on for a very short time... Not even long enough to get to the service screens... (bad used replacement board)... I took another look at the original LD board and found that the 19v power supply was good at the white fuse above the power connector but was missing at the two 22mfd 50v surface mount caps... There was a direct short across these caps and an extremely small 5a fuse blown (located to the right of the power connector aprox 5/8" from the lower board edge)... This looks like an extremely small resistor...
                                There are numerous capacitors across these filter capacitors from B+ to ground... I found one chip capacitor (located just to the lower left of the CN2000 LED connector) that was shorted and was shorting out the 19v line and making the 22mfd caps "look" bad... I replaced the shorted cap with a small value disk cap (around 22pf) and scraped off the green copper resist areas where the tiny fuse was located and soldered in a standard "F" type 5 amp glass fuse.... No more flashing LED and the set fired up and worked beautifully... Less than a dollar invested in a freebee LCD TV...
                                I did spend the time checking the LED strips before doing the board repair and found they were not the original fault... Both boards were the problems...
                                I hope this may help others with this model Sony...
                                Dave
                                • petersor
                                  • Feb 2020
                                  • 43
                                  I also had a Sony with 6 flashes on the standby LED - model KD-60x690E. Thought I'd post what i found. The problem was intermittent, so it was hard to trace, but checking the LED strips with a backlight tester showed one of the sets (combined A & B strips) had an operating voltage about 5 volts higher than the others. Each of the individual LEDs tested OK as did the individual A and B strips. I noticed that the connector between the two sections appeared to have small burn marks where the small clips on the B strips touched the contacts on the A strip. I cleaned the contacts and clips and reseated all the sections toghether, but adjusted where they joined slightly so the spring clips touched a different part of the contact area. Hard to believe that 5 volts high would trigger protection mode, but it makes sense, I guess. Hope this helps someone.
                                  • petersor
                                    • Feb 2020
                                    • 43
                                    In retrospect (i.e. after the TV was back on the wall), I probably should have just soldered the strips together, eliminating the connector as the weak link . . .
                                      • 12085
                                      • U.S.
                                      #38
                                      Originally posted by petersor
                                      in retrospect (i.e. After the tv was back on the wall), i probably should have just soldered the strips together, eliminating the connector as the weak link . . .
                                      +1
                                      • Audeze
                                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                        by Audeze
                                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                        Does...
                                        10-06-2024, 08:54 PM
                                      • bialag
                                        Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                        by bialag
                                        I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                        Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                        03-25-2025, 05:56 PM
                                      • Watson306
                                        6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                        by Watson306
                                        I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                        I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                        I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                        Many Thanks in advance.
                                        11-01-2022, 05:33 AM
                                      • shahnld
                                        Sony kdl 65xg9505 green amber blinking
                                        by shahnld
                                        Good Day.
                                        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                        01-03-2024, 03:05 PM
                                      • cheeky2
                                        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                        by cheeky2
                                        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                        01-08-2024, 05:56 AM
