Blaupunkt 49/235Z-GB-11B-FGU-UK blue standby light
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Blaupunkt 49/235Z-GB-11B-FGU-UK blue standby light
    When you say you bridged the connector, what exactly did you bridge> It doesn't stand to reason if the separate strips all the LEDs light up but when you connect only half light up. Did you bridge across or along? If you bridge across, only half the LEDs will light up. Can I see a picture of what you did?
    • sordids999
      • May 2013
      • 2161
      Right sorry to confuse things but this is what I have done to try and get it to work and now the first strip works if I use the test points
      So there must be a break somewhere on the negative side on the first strip ?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes there is a break there.
        • sordids999
          • May 2013
          • 2161
          It's strange how all six are the same though
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Indeed strange. Perhaps they all got some mechanical stress from manufacture? So what do we have now ^ pairs of strips and all 12 LEDs working on each strip?
            • sordids999
              • May 2013
              • 2161
              #26
              Ok so doing this only lights up one side of the strip but at the top strip if I go from one side of the negative point to the other side the led strip lights up fully
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #27
                The extra wire you have on the top strip gets the entire strip to work. You may have to do the same with the others to get all to light up.
                • yohnsee
                  Semi-noob
                  • Dec 2017
                  • 198
                  • Hungary
                  #28
                  Just a quick tought here.
                  Isn't it strange, that all of the strips need a jumper wire halfway?
                  If I got it right, your LED tester can only light up half of it at a time.
                  I have a different kind of tester, and last time I had to open a 32" LG to test the LEDs, because all of them were in series, and my tester couldn't get enough voltage trough them to open.
                  I hope this is not misleading in any way, I just wrote my experience here.
                  Cheers, Janos
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    #29
                    Good thought...I am concerned as well. What kind of LED tester do you have and what voltage does it go up to? Also to ponder on this a bit...For the LEDs to light up and only half of the strip to light up is a bit puzzling as the one half of the strip SHOULD light up independently of the other half furthest from the supply connector but the other half closest to the supply connector SHOULD NOT light up independently.
                    • yohnsee
                      Semi-noob
                      • Dec 2017
                      • 198
                      • Hungary
                      #30
                      It is this knob-switch type:
                      You can chose almost everything on it, but it only goes up to 200V. This time I spoke about earlier, the LED driver was settled around 210V, so that's why mine couldn't light up all of them. I had to disassemble the display to test the stripes individually X-(
                      Regarding the post: if the stripes test good in halves, and the OP can measure the resistance between 2 connected stripes (~0Ohm) then there is not much left to test here. I would rather move towards the mainboard, as I already repaired 2 Blaupunkt sets with this "stuck-in-standby mode", by changing the eprom (these T.xxxx mainboards usually operate on 25Q32 or similar) to a new one, and getting a trusted working flash from the internet. You also need a good eprom writer.
                      Cheers, Janos
                      • sordids999
                        • May 2013
                        • 2161
                        #31
                        Ordered this one
                          Are we not talking jumping the connector that link the two LED strips together?
                          https://www.badcaps.net/forum/showth...124#post690124
                          • sordids999
                            • May 2013
                            • 2161
                            #33
                            Started to have another look at this tv tonight and now all backlights are working without any jumpers all removed last night
                            Confused ! How this is happening
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              #34
                              loose connectors linking the left side and the right side.
                              • yohnsee
                                Semi-noob
                                • Dec 2017
                                • 198
                                • Hungary
                                #35
                                Yes, they can be. OP could test it, while the strips being powered, try to gently push on the connectors that join the left/right side. See, if they stay on or not.
                                Cheers, Janos
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  #36
                                  Yes we suggested that but I'm not sure if he understood when I said 'bridge'.
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    #37
                                    Know this is an old thread, but thought Id share my experience, same model, same probem. Once I got everything positioned so all LEDs illuminated, I put a blob of glue from glue gun on the joints to help hold them in place.
                                    • cockalomg
                                      Blaupunkt blaupunkt b32she188tchd-100 no standby light
                                      by cockalomg
                                      Does anyone have a schematic for this board?
                                      I have no output voltages, no standby voltages.
                                      The fullbridge rectifier has a permanent 330V
                                      there is no voltage on the two large black electrolytic capacitors​
                                      11-05-2024, 03:01 AM
                                    • Tomylee
                                      Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                      by Tomylee
                                      Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                      Here's what I've observed:
                                      All ribbon cables are properly connected
                                      Battery is present and in good condition
                                      No reaction even with screens disconnected
                                      There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                      I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                      06-26-2025, 02:33 PM
                                    • brithepi2k
                                      Sony KD-65XE8596 no standby light
                                      by brithepi2k
                                      I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                      cheers...
                                      09-06-2025, 02:22 PM
                                    • Kaar3l
                                      Samsung QLED QE65Q7FNAT only standby light
                                      by Kaar3l
                                      TV: Samsung QLED QE65Q7FNAT
                                      PSU: BN4400940A
                                      MB: BN94-12832K
                                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                      09-24-2024, 01:35 PM
                                    • Nicktronic
                                      Samsung UN70NU6070F Standby Light flashes twice
                                      by Nicktronic
                                      Hey Everyone,
                                      So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                      I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                      03-27-2023, 07:01 PM
