2010-built Panasonic TC-L42U22
  • RJARRRPCGP
    • Jul 2004
    • 6304
    This is an LCD with CCFLs, unlike what a lot of folks seem to think, when they hear "Panasonic", especially before the mid-2010s.
    I have a problem with image retention, I saw artifacts of a recently used PC program, LOL. (The menu, IIRC)
    It retained an image at the top, of the top part of a program that I had open.
    Is the panel finally taking a shit, or do I need to reseat a connector or the like?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: 2010-built Panasonic TC-L42U22
    I think this simply has major image retention, but unlike a plasma one, I don't know if it's even possible to get to the service menu and adjust any voltage.
    It's much worse than a CRT, LOL! The Pale Moon bar is easily seen and since this morning, I see parts of the badcaps.net message board
    burned in, IIRC, LOL.
    Arc A770 16 GB
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      T-CON Bd or Panel issue. Measure the Vgl (-5V~-7V) and Vgh (20V~30V)voltages on the T-CON Bd. They may be missing or low. If these are not correct disconnect the T-CON to Panel cable/s and see if the come back up.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Shit! I don't even have a multimeter, LOL. It wouldn't surprise me if I need to clean the T-con connectors with alcohol, LOL.
        Should I just do a gambling mission by getting a T-con board off the internetz? (As if I were gambling with ##!#!!! plasma TV board?)
        Arc A770 16 GB
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          With so many posts I don't believe you Anyway you could just get another T-CON Bd. to swap. and yes give the connectors and FFCs with IPA
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Judging by some dust I saw from the outer back, with a lot of it appearing to be on the inner side, it definitely looks like IPA time, just hope there's no Pioneer-like trap switch!
            I have posted a ton, despite not getting the equipment I need to service some stuff and I wish I had a good soldering station and plenty of rosin-core solder and de-soldering braids. Then it really got ugly in 2016, because I had to move many times, I moved like it was The Oregon Trail, LOL.
            https://en.wikipedia.org/wiki/The_Or...8video_game%29
            Arc A770 16 GB
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I understand your pain, Bro.
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • aa10aa10
                Panasonic Toughbook CF-33 mk1 BIOS repair
                by aa10aa10
                Good day,
                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                01-21-2025, 06:13 AM
              • Mnawar27
                Panasonic CF-H2AU24EF3 bios locked
                by Mnawar27
                Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                I need help to remove it,
                thankyou all.
                SN; 2FKCA26876...
                11-16-2024, 08:00 AM
