Samsung PN64D8000 - Power Supply Board Issue?
  • overdrive1012
    • Jun 2018
    • 22
    We were watching TV the other night when I heard a pop followed by the TV going out. No standby light, nothing.
    Immediately, I opened the back and noticed that one of the fuses on the board (BN44-00447A) had blown. I thought I could replace the fuse and cross my fingers that nothing else was bad. I replaced the fuse and plugged in the TV, immediately the other one popped. I replaced that one and plugged back in and this time around I heard/saw a pop, which tripped the circuit breaker. This time around, a thermistor blew.
    I'm thinking that before I replace that thermistor, something else is amiss.
    It seems that these boards are a little hard to come by and not cheap. It's been a little while since I picked up a soldering iron (last time I did, I accidentally fried a PS2) so I'm hoping I can get some guidance on where to start.
    Thanks,
    J
  • CapLeaker
    Leaking Member
    • 8147
    Re: Samsung PN64D8000 - Power Supply Board Issue?
    Usually there is a reason why a fuse pops. So keep putting in fuses you may do more damage. First off you have to figure out "WHY" the PSU keeps popping fuses. So first logical thing is to do is to make some straight shot, high resolution pictures of your boards front and back, so we can see things clearly. Check the primary section of the PSU. Be careful, there can be very high voltages when plugged in and running. Fist item to check on your PSU in this case is the bridge rectifier for a short. If that is shorted, it's bad.
    • R_J
      • 9535
      What "thermistor" blew, it was likey an MOV. what was its location number or part number on the component. These boards also develope bad solder connections on the transformers and mosfets mounted to the heat sinks, they need resoldering especially the connections that use a rivit.
      • overdrive1012
        • Jun 2018
        • 22
        This is the thermistor that blew. I'm going to pull the board and see if I can see any other damage.
        • overdrive1012
          • Jun 2018
          • 22
          Sorry, didn't attach the image. DSC 20D-20 Thermistor. See the blow hole on the bottom right side.
          • R_J
            • 9535
            Ok, that one is the thermistor, Also check the resistance across the blue mov's maybe one of them shorted also, if not just replace the thermistor and don't forget to check or resolder those connections I mentioned.
            • overdrive1012
              • Jun 2018
              • 22
              Also have a blown MOSFET. See the pinhole and the char mark.
              • R_J
                • 9535
                That would do it. Did you have a look at those other connections for cold solder joint? I bet one of the connections on TS801s primary is bad.
                • overdrive1012
                  • Jun 2018
                  • 22
                  So, impatient as I am, I ended up picking up a TV on craigslist that had a broken panel for $30. Power supply was good so I just swapped it to this one and I'm back in business, but will eventually fix this one as a backup.
                  • Nicktronic
                    Samsung Power Supply Board BN44-00874F
                    by Nicktronic
                    Hey everyone,
                    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                    Anybody...
                    03-17-2025, 06:20 AM
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                  • repair-it
                    Need advice testing a samsung power supply board with scope
                    by repair-it
                    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                    07-12-2025, 11:00 AM
