BUSH 22" TV kEEPS BLOWING INTERNAL FUSE
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi Guys i got this tv from a friend to see if i could fix it for him he said he plugged it in and it went bang so i opened it up and noticed a resister with a chip on it so replaced it and also q1 which was shorted ( circled in red ) which is a FQPF8N60C transiter so replaced that and also two diodes (RL205 ) which was testing both ways so replaced them it its still blowing the fuse any ides guys any help much appreciated
    Your never to old to learn
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: BUSH 22" TV kEEPS BLOWING INTERNAL FUSE
    What is the part number on IC1 on the underside of the power supply?
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Cheers Dick_Barton its a js2269sp
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I can't find any information on it but maybe someone will be able to.
        • R_J
          • 9632
          Were all three legs shorted on Q1 fet, if they were its a VERY good chance the ic is bad. ic's don't like 160v on gate drive pin.
          Seems to be same as OB2269
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            I couldn't find any info either on that chip. I will check tonight when I get home and check for short on pins and let you guys know cheers
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Looks like JS2269 to me or is the J an O with part of the print missing?
              • garrymc123
                • Apr 2010
                • 336
                • United Kingdom
                Hi Guys have tested the ic1 and no shorts found but I have found that I have continuity on cap 1 is it because its a 400v cap on the primary side the multimeter has continuity on this cap?
                  How did you go about testing for shorts on that IC?
                  What resistance do you see on the main filter cap?
                  The replacement MOSFET still tested OK?
                  When that MOSFET shorted out it will more likely take out the IC at the same time, and if IC output stuck high it will cause the new MOSFET to be stuck on and will blow the fuse and may also damage the new MOSFET.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Originally posted by budm
                    how did you go about testing for shorts on that ic?
                    The replacement mosfet still tested ok?
                    When that mosfet shorted out it will more likely take out the ic at the same time, and if ic output stuck high it will cause the new mosfet to be stuck on and will blow the fuse and may also damage the new mosfet.
                    +10
                    • garrymc123
                      • Apr 2010
                      • 336
                      • United Kingdom
                      Hi Guys Yes all three legs shorted on q1 I tested ic1 with continuity on each pin and had no bleep on the meter and I'm getting 000.9ohm resistance on the main cap I have just rechecked q1 and all three legs are shorted again and I'm getting continuity on all three pins from q1 to pin1 which is ground on ic1 ..Will I replace q1 and ic1 and take it from there is there anything else I should check and also what will I replace ic1 with if I can't find any info on it.. will OB2269 do the same job .. Thanks in Advance
                        Need to check for any damaged parts (resistors, diode) between the Gate of the MOSFET and the Gate drive pin of the IC.
                        • garrymc123
                          • Apr 2010
                          • 336
                          • United Kingdom
                          Hi Guys did a couple of checks on the power board I'm going to replace the main filter cap as it's out of range and also ic1 and q1 q1 was shorted on source and drain i can't find anything else wrong checked all the smd caps and none is shorted how would I check the smd resistors. Thanks in Advance
                          • corrize
                            A funny fuse story – Lumix LX100 II
                            by corrize
                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                            10-19-2023, 09:58 AM
                          • Acnologia
                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                            by Acnologia
                            Here is a pretty crazy one.
                            Step 1.
                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                            Step 2.
                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                            Step 3.
                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                            Step 4.
                            Lets ,dive into the board. I see the edp cable on the...
                            05-07-2025, 07:16 AM
                          • jshhh
                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                            by jshhh
                            Hi guys,
                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                            Anybody know how to remove this type of fuse?
                            (The fuse is toward the bottom of the image labeled F2)...
                            06-17-2025, 01:35 AM
                          • stav242
                            Samsung BN44-006056A Blowing Mains plug fuse.
                            by stav242
                            ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
                            It was reported as `blowing the fuse` - the 3A one in the plug.
                            on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
                            Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
                            Can anyone identify what CM802 is ?
                            thanks.
                            S....
                            12-30-2021, 10:45 AM
                          • Loretto
                            Samsung SMPS BN44-00339A
                            by Loretto
                            this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                            I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                            I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                            I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                            03-29-2025, 08:30 AM
