LG 42LV 4400 Will not come on
  • davg
    • Sep 2008
    • 536
    Re: LG 42LV 4400 Will not come on
    Originally posted by budm
    Right now the problem is on the main board, what the exact cause for it not to send PS-ON (<1Vdc = OFF, >2Vdc = ON) I do not know. You may try heating and cooling the main board to see if the PS-ON will be present or not.
    Thanks Budm appreciate your response. Heating and cooling? Are you thinking 385 degree for 10 minutes in the oven? I have read about this but not tried it. Do it actually work? Are there issues with things on the board that could melt at that temp?
      • 12276
      • U.S.
      #42
      One there for 48 bucks. https://www.ebay.com/itm/LG-42LV4400...IAAOSw48dbIkcQ
      • Jazzotiti
        • Jun 2018
        • 31
        • France
        #43
        Hello
        No, Budm does not talk about putting the electronic card in the oven.
        I think rather to the use of an electronic bomb of cold.
        For the hot test. the dry hair of madam in position hot air.
        That should be enough ..
        This will expand or contract the circuit and may be exposed to a problem of electronic welding, bad contact.
        Baking is the last resort option if I dare say ...
        Cordially
        Thierry
          • 12276
          • U.S.
          #44
          That would be using a hair dryer, hot air gun or freeze spray, inverted can of duster, to heat or cool board to see if tv starts working, to try to narrow down the faulty area.
          • davg
            • Sep 2008
            • 536
            Tks reading the full description indicates the board has the same issue as mine? Not tested working?
            • davg
              • Sep 2008
              • 536
              Tks for the responses; I will give it a try and see what happens. This seem to be where the problem lies?? As I indicated in an earlier post the unite stopped working, my friend took it out of service for several months before giving it to me. When I got it home and powered on it worked fine for about 6 hours I turned it off in the night and the next morning it would not come on?
                • 12276
                • U.S.
                #47
                Oops, my bad, I thought it read display is cracked but it said display is not cracked.
                  • 12276
                  • U.S.
                  #48
                    • 12276
                    • U.S.
                    #49
                    Oh, you're in Canada, I got you mixed up with a poster in the U.K. you can probably just get it straight from shopjimmy then. http://www.shopjimmy.com/lg-cov31310...2lv4400-ua.htm
                    • davg
                      • Sep 2008
                      • 536
                      Shopjimmy is out of stock and I am not sure they ship to Canada
                        • 12276
                        • U.S.
                        #51
                        Ok, shopjimmy ebay, this one has two components, there's others there on ebay but who knows where they are from, I would go with this: https://www.ebay.com/itm/LG-COV31310...wAAOSwEeFVHtcB
                        • davg
                          • Sep 2008
                          • 536
                          So are you indicating that these two components will fix my board?
                            • 12276
                            • U.S.
                            #53
                            NO, I am not, it's just the course of action that I would take in this situation, mainboards are pretty complicated, I would throw that 20 bucks at it, if that didn't work, I'd probably just part it out, minus mainboard of course. It could be bad bga or a lot of other possibilities, LGs are well known for needing reballs n reflows and such, there's a lot of LGs on this site with those problems in just the past couple weeks.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #54
                              i would certainly give the ebay repair kit a try if i was fault finding this set myself.
                              • davg
                                • Sep 2008
                                • 536
                                Tks guys I will attempt to acquire the kit if I can find an ebayer who ships to Canada I have nothing to loose?? So would these eeproms have to be replaced in pairs?
                                • davg
                                  • Sep 2008
                                  • 536
                                  Just tried placing order with shopjimmy ebay but they will not ship to Canada?? Can you recommend another source? I assume these eeproms have to be programmed for specific boards ie; Main Board Component Repair Kit for 42LV4400-UA
                                  • R_J
                                    • 9588
                                    Shopjimmy ships to Canada all the time. Unless they have recently changed "F#^^'n Trump"
                                    From Shopjimmy - Help - FAQ
                                    Shipping
                                    • Do you ship orders the same day?
                                    • When will I receive tracking information for my order?
                                    • Can you ship internationally?
                                    Yes, we can ship our products to just about every country on this great, green Earth. We cannot ship to P.O. boxes at this time, however.
                                    • davg
                                      • Sep 2008
                                      • 536
                                      Must have changed their policy cause I can't get pass the first screen Buy it now? I get a screen saying "Do not ship to Canada"
                                      • R_J
                                        • 9588
                                        I can no problem, I click on add to cart, Part is in shopping cart, proceed to checkout takes me to secure checkout where you fill in all your information
                                        Are you using Shopjimmy site or Ebay
                                        Just go to the shopjimmy site, you will not have a problem
                                        • davg
                                          • Sep 2008
                                          • 536
                                          EBay
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
                                          • tmhobadcap
                                            Pioneer VSX-522-K remote control not working???
                                            by tmhobadcap
                                            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                            12-24-2020, 01:44 AM
