LG 42PC1D No Video
  • mnow
    • Jul 2014
    • 18
    • usa
    LG 42PC1D No Video
    Got a LG 42PC1D with no video display!
    Va and VS are normal and assume that Vy of 122v and VSC of 188V is normal also (might have those mixed up). Z board seems to be working as well.
    So why no picture?
  • maxvalutech
    • 804
    • australia
    Re: LG 42PC1D No Video
    Yes.
    • mmartell
      • Oct 2013
      • 3189
      IPM's ?
      • mnow
        • Jul 2014
        • 18
        • usa
        Wouldn't the IPM be working if VSC and Yv are there?
        • mnow
          • Jul 2014
          • 18
          • usa
          Can the Ysus board be checked without the drivers connected? Need to measure voltages at different pinouts to verify IPM!
          • mnow
            • Jul 2014
            • 18
            • usa
            OK, Just scoped the Y outputs and there is signal there with -Vy @ 200v, VSC @ 120v. On the Z board, signal also scoped with a Z-bias of 100v and no picture on the screen. Is it possible the sacreen could be bad?
            • mnow
              • Jul 2014
              • 18
              • usa
              Anyone have some input to this problem?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Are the voltages on the label the same as those you measure. Vs, Va, etc?
                • mnow
                  • Jul 2014
                  • 18
                  • usa
                  All voltages at normal rating! Scoped the Ysus driver and Zsus boards and all signals appear normal. I do however have one red LED on the logic board (all others are green).
                  • Wilderone
                    • May 2018
                    • 76
                    Do you have any glow on the panel when the TV is powered on?
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      the vital signs are OK. A red LED on the Logic Bd. is indication of a problem there. Either it is not getting a healthy 5V supply or some other component malfunction.
                      • mnow
                        • Jul 2014
                        • 18
                        • usa
                        No glow on the panel at all Wilderone.
                        Yes I agree that red is bad. All the power rails are at spec and clean DC.
                        If only could find a service manual on this, would help greatly.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Look at the CTRL Bd and search for 2 pins/holes labeled AUTO-GEN. Disconnect the Main Bd. from the CTRL Bd. Solder/connect a jumper between the AUTO-GEN pins/holes. Apply the ac and if the Panel is good the Test Patterns should show. If the screen shows a perfect White display, then the Panel is OK and your Main Bd. or LVDS cables is the fault.
                          • mnow
                            • Jul 2014
                            • 18
                            • usa
                            Thanks Andrew, will try that tomorrow.
                            • mnow
                              • Jul 2014
                              • 18
                              • usa
                              Finally got to that TV and found the auto-gen, problem is that it is a 4 pin header and not sure which pins need to connect.
                              • R_J
                                • 9625
                                The center 2 pins are common, I would think either pin 2or3 to pin4. Other ctrl boards auto_gen connect the 2 pins with the resistors off them.
                                • mnow
                                  • Jul 2014
                                  • 18
                                  • usa
                                  OK, Jumpered pins 3 and 4 on auto-gen header with and without LVDS cable connected. Still black screen! The only difference noted was that LED 1 and 3 came on in the CTRL board rather than LED 2 and 3 without the jumper. They are outlined in red.
                                  • Markus1
                                    • Jul 2013
                                    • 80
                                    You can find the Service Manual under this address:
                                    https://archive.org/stream/LG_42PC1D#page/n0/mode/2up
                                    Hope it works.
                                    • mnow
                                      • Jul 2014
                                      • 18
                                      • usa
                                      Unfortunately incomplete just like all the other schems out there!
                                      Does not show the complete picture.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        To do the AutoGen test, you have to disconnect the PSU from the Main Bd. and the Main Bd. from the CTRL Bd. Then you would have to put the PSU in Self-test mode to turn it on.
