Vizio D65u-D2 VIVID Setting = LED Shutdown
  • Michale32086
    • Nov 2011
    • 1453
    Have a Vizio D65u-D2.. Works great as long as VIVID or VIVID-esque settings are not used..
    If VIVID is used, the LEDs shutdown after a couple minutes...
    Is this indicative of a bad LED strip(s) or a problem with the Main Board??
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: Vizio D65u-D2 VIVID Setting = LED Shutdown
    You have to specify a little better what happens when it shuts down. Like does it still play audio just the back light turn off, or does everything just turn off?
    So monitor PSon and BLon with your DMM and see what happens.
    If the back lights just turn off on vivid, you can probably do the same in any other mode. You just have to crank up the back lights full tilt and wait. LED's can fail while they are stressed under full load, but still work fine when the power is reduced. May be a bit tricky to find, but worth to look at it.
    • Michale32086
      • Nov 2011
      • 1453
      Yer right, I should have been more specific... Apologies..
      Yea, it's just the backlights that go out... I still have picture and sound... And you're also right, it's not just the VIVID setting. Any setting (GAME, COMPUTER, ETC) where the display is notably brighter, it happens.. This indicates an LED Strip issue...
      Another curious thing is that the power LED won't stay on, even though it's set in the menu to stay on all the time that the TV is on..
      That would seem to me to indicate a Main Board fault..
      I won't be able to get it on my bench until Tue..
      Thanx for the input....
      • geeforce
        • Oct 2017
        • 87
        Did you fix this?
        • Michale32086
          • Nov 2011
          • 1453
          No I did not.. I explained to the customer he would have to keep the setting away from VIVID and he said that was good enough..
          But I am still convinced that replacing a bad LED Strip would fix the issue..
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • howardc64
            Vizio SmartCast TV software bug that looks like hardware
            by howardc64
            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
            11-16-2024, 05:17 PM
