I need help decoding a bad cap LG plasma tv (60pv450)
  • Saraleigh
    • May 2018
    • 5
    Hi guys. I'm new to this & see the this community is awesome. U guys freely give advice over & over. So I want to thank u ahead of time.
    My issue is a LG plasma tv (60pv450). I read enough to see that the cap on c802 was bad. I'm trying to decode this cap & im just not getting it. Can u help me. The cap reads FL 1.5 KHP 333H S K42, so far I've got out of this is
    33000pf at 1.5kdv .
  • petehall347
    • Jan 2015
    • 4438
    • United Kingdom
    Re: I need help decoding a bad cap
    does it look like this one ? http://www.signalsuk.com/Shop/Capaci...500V-592H.html
    • petehall347
      • Jan 2015
      • 4438
      • United Kingdom
      does it have a makers logo on it ?
        Any good clear pictures of the cap?
        • Saraleigh
          • May 2018
          • 5
          It has the marking that I referenced in the Initial post
          • Saraleigh
            • May 2018
            • 5
            Hey guys. Would u mind taking a look at this. Tell me what u can make of ut
            • R_J
              • 9588
              Are you sure the cap is bad? it is usually the black square type that bulge that are bad.
              This one from digikey would work 495-4767-nd or 399-12622-ND (2kv)
              • Saraleigh
                • May 2018
                • 5
                I'm fairly sure it's bad. It appears to be bulging on the sides. However I didn't test it yet. Was trying to identify it first.
                Thank u so much for the product code
                • R_J
                  • 9588
                  That green cap you posted looks ok. it looks original and not bulged, it was never square. I believe that cap that goes bad is on a different power supply board but same location.
                  Since you never mentioned what the problem is, I suspect there are other issues.
                  this is what the bad ones would look like
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Originally posted by R_J
                    I'd expect dry capacitors to immolate before seeing something like this... at least if I assume that's a polystyrene/polypropylene capacitor.
                    I imagine there's a story behind this capacitor, what kind was this really, and how did this happen?
                      I have seen many polypropylene with same failure in lots of Samsung, look for CI818.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Which model?
                        CI818 seems to point to many different inverter board capacitors... but how is this thing stressed to cause it to bloat like that -- or is it just a capacitor manufacturing QC problem?
                          Many models, the cap that failed is used for coupling/DC blocking from the Bridge drive to the primary winding of the inverter transformer, or power transformer.
                          "but how is this thing stressed to cause it to bloat like that" I have no idea, it is needed to be taken apart and analyzed.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Okay that one is a bit more voltage "stressed" - I saw another schematic when I searched for a Samsung CI818 that was a 0.01uF filter capacitor hooked up directly to an input of a LM393 op amp and was wondering how that could possibly be stressed...
                            • ArMaaN376
                              Samsung PS51E550 Plasma TV
                              by ArMaaN376
                              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                              Opened TV cover & observed foll
                              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                              How to confirm Y -Buffer board...
                              06-19-2024, 04:05 AM
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • KYBOSH
                              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                              by KYBOSH
                              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                              No picture but you hear the TV static (white noise) playing loud and clear.
                              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                              But it seems they didn't get too far and just left it.
                              When I first took a look I was amazed at how pristine the inside looked.
                              Its as if the TV had been in a time capsule.
                              Caps looked like they were just pulled off the self.
                              Copper coils had no sign of corrosion on...
                              02-01-2023, 11:10 PM
                            • chazh
                              LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                              by chazh
                              This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                              I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                              The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                              09-01-2025, 08:56 PM
                            • porfyriadhs
                              Samsung Plasma PS51D6900DS Bootloop
                              by porfyriadhs
                              Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                              Thanks a lot !!
                              10-19-2023, 11:31 AM
