Un55mu630df
+ More Options
Posts
  • fcisolutions
    • Jan 2017
    • 205
    Un55mu630df
    Hello I have a Samsung UN55MU630DF television. I have tested the power supply and getting good reading on my voltages. 12.2 and 3.34. I replaced the main board because initially it would not even come on. Now the back lights flash on and off in a cycle. No T-Con but did replace ribbons from main to panel.
    • 12086
    • U.S.
    Re: Un55mu630df
    Can you throw up some good clear pics?
    • fcisolutions
      • Jan 2017
      • 205
      Re: Un55mu630df
      Here are some pictures of the boards.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Re: Un55mu630df
        Can you give the voltage readings on the 12 way connector CNM803 (blurry so hard to read) and the legend name alongside it.
        • fcisolutions
          • Jan 2017
          • 205
          Re: Un55mu630df
          CNM803
          Pin 1 - .01V
          Pin 2 - 3.21V
          Pin 3 - 12.67V
          Pin 4 - 3.47V
          Pin 5 - 12.67V
          Pin 6 - 3.15V
          Pin 7 - 12.67V
          Pin 8 - 4.41V
          Pin 9 - 12.67V
          Pin 10 - .01V
          Pin 11 - .01V
          Pin 12 - .01V
            Re: Un55mu630df
            Can we please get the name of each pin?
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Re: Un55mu630df
              Without the legend corresponding to the pin numbers the readings are not much use.
              • fcisolutions
                • Jan 2017
                • 205
                Re: Un55mu630df
                This is what I got.
                  Re: Un55mu630df
                  So ALL the control signals are all stable while the Backlights are flashing?
                  • CapLeaker
                    Leaking Member
                    • 8028
                    Re: Un55mu630df
                    What happens if you unplug the main board from the PSU, then plug the TV in? Back lights should turn on and stay on.
                      • 12086
                      • U.S.
                      Re: Un55mu630df
                      http://www.shopjimmy.com/samsung-bn4...-led-board.htm picture if thats it.
                      • fcisolutions
                        • Jan 2017
                        • 205
                        Re: Un55mu630df
                        Yes if I unplug the main board from PSU backlights come on and stay on.
                          • 12086
                          • U.S.
                          Re: Un55mu630df
                          Originally posted by fcisolutions
                          CNM803
                          Pin 1 - .01V
                          Pin 2 - 3.21V
                          Pin 3 - 12.67V
                          Pin 4 - 3.47V
                          Pin 5 - 12.67V
                          Pin 6 - 3.15V
                          Pin 7 - 12.67V
                          Pin 8 - 4.41V
                          Pin 9 - 12.67V
                          Pin 10 - .01V
                          Pin 11 - .01V
                          Pin 12 - .01V
                          Try these readings again, need them with tv plugged in and then with power switch activated, see if any change value when you hit power button, report findings.
                          • joecop67
                            • Apr 2013
                            • 8
                            Re: Un55mu630df
                            What's going on? I can't start a thread? I don't have permission to check my own stats.
                            • joecop67
                              • Apr 2013
                              • 8
                              Re: Un55mu630df
                              It says I have 1 post, but I've made hundreds of the years.
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                Re: Un55mu630df
                                Never mind. Wrong username for this forum. It's Malachi here. Lol
                                Delete.
                                  • 12086
                                  • U.S.
                                  Re: Un55mu630df
                                    • 12086
                                    • U.S.
                                    Re: Un55mu630df
                                    Looks and acts like mainboard but seeing how bad these samasungs are, I think it's the powersupply.
                                      • 12086
                                      • U.S.
                                      Re: Un55mu630df
                                      Check all your diodes and resistors.
                                        Re: Un55mu630df
                                        If the backlights come on and stay on without flickering then your power supply board, LED driver and LEDs are OK.
                                        But as I asked in post #9, are your sure that the control Voltages (not the A13V) are stable?
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
