Samsung UE58J5200 LED fail repeatedly
+ More Options
Posts
  • hifiguy
    Geoff Scott
    • Jun 2011
    • 12
    Hi folks
    Has anyone had this before? UE58J5200 no backlights. When stripped to the leds I observed that a number of the leds had blown, ie burnt.
    The customer said it crackled when it went off.
    Ok so when I saw the damage I thought as a matter of caution to replace the PSU too. When the strips arrived I checked each and every one and they were all good...Changed all the led strips and PSU...It arced immediately and promptly took the leds out! I've cut my losses and the TV is scrap, but I'm just wondering if anyone may have any ideas as to the cause?
    Geoff
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UE58J5200 LED fail repeatedly
    If it was 'new' PSU and LEDs then I can only guess that you connected the LEDs in the wrong direction. If it was 'new' LEDs only then I may be tempted to say PSU destroyed them.
    • hifiguy
      Geoff Scott
      • Jun 2011
      • 12
      Thanks Andrew.
      The PSU was a reclaimed one. I'm thinking it may have had the same fault as the original.
      We live and sometimes learn.
      Geoff
      • hifiguy
        Geoff Scott
        • Jun 2011
        • 12
        For those who might be interested.
        The LED strips on this set have connectors for left and right linking. Hard wired them and the edge connectors and that cured the failing.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          So the PSUs are OK, then??
          • limo
            • Jan 2021
            • 5
            • P
            TV: UE58J5200
            PSU: BN44-00787A
            Backlit: https://sklep-elwron.pl/pl/p/-LED-Sa...H058BGNV1H/116
            12 LED rails (6x DMGE-580SMA-R3 , 6x DMGE-580SMB-R3)
            LED: 14 (7+7)
            Symptoms: no screen / backlit on but dim
            CNM803 (under load):
            1,3,5,7 (A13V): 12.79V
            9 (GND): 0V
            CNL802 (under load / without load):
            1 (D1+): 350V / 350V
            2 (D1+): 350V / 350V
            4 (S-): 227V / tbd
            6 (S+): 227V / tbd
            8 (D2-): 108V / tbd
            9 (D2-): 108V / tbd
            Are these values on CNL802 pins (especially from 4 to 9) ok?
            Board:
            • limo
              • Jan 2021
              • 5
              • P
              Next steps:
              PSU:
              1. Measure resistance and voltage drop on R9162. Calculate current.
              2. Measure resistance of two LED channels (without and with load).
              3. Measure all CNL802 voltages without load. Compare results with: https://m.youtube.com/watch?v=xyw9AWLwCHU
              4. Check MOSFETs / diodes for short (some are checked).
              5. Replace leaked CM841 10uF/350V cap (capacitance and resistance is OK now).
              T-CON:
              1. Check three blue LEDs status (power supply voltage, fuse).
              LED:
              1. Since I do not have backlit tester and backlit LEDs are faulty (see burned spots on PCB under R9162, Schottky diodes and MOSFETs) I am going to disassembly steel cover to check LEDs.
              • R_J
                • 9535
                Start by replacing the bad capacitors, there is at least one that is bulged on top. There may also be a shorted mosfet Q9101c on the back side of the board.
                • limo
                  • Jan 2021
                  • 5
                  • P
                  Thank you for reply. I appreciate any advice however:
                  Cap seems to not to be a big problem now (PSU seems to be working but overloaded due to faulty LEDs - that is why TV is turned off).
                  When Q9101 is faulty (open/short) then there is no A13V so this is not my case but I did not have much time to analyse PCB trace / pads connections (maybe there will be some similarity with BN44-0632A schematic).
                  • Storyteller12
                    • Jun 2020
                    • 624
                    Just about all of these 58” Samsungs have bad backlights that need replacing. The leds fail and take out the power supply also. There are a few threads on this
                    • R_J
                      • 9535
                      Q9101 is part of the led boost circuit. If it was shorted, it could kill the A13V if open it would not.
                      • limo
                        • Jan 2021
                        • 5
                        • P
                        PSU checked again (MOSFETs and diodes): no shorts
                        D1 line voltage: 120V
                        D2 line voltage: 110V
                        Calculated current on R9162=1.58 Ohm power resistor is 0.115A.
                        Power voltages on all boards seems to be OK 12.75V, 1.5V, 1.0V depending on circuit and IC).
                        Backlit: one LED broken (no big deal)
                        After reassembling screen and replugging two T-CON flex cables there is an image (menu) but with ghosting:
                        Faulty LCD screen, T-CON board?
                        Next steps:
                        1. To reassembly screen again (right side LCD bezel on the picture is not assembled well).
                        2. To clean pads on all flex tapes.
                        3. Check flex tapes conductance.
                          • 12181
                          • U.S.
                          Tape cutoff method may clear it up: https://www.youtube.com/watch?v=pfrRhw7-ZII
                            • 12181
                            • U.S.
                            Something to try, turn down the backlights see if it clears up any.
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                              This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 06:20 PM
