Can't Melt Solder on Power Board
  • barryra
    • Aug 2013
    • 107
    I am changing a bunch of capacitors on a power board in my 47pfl7403d/f7 & cannot budge any solder. I've tried adding new solder with no luck. My Hako iron is at 750. Thanks for any help.
  • arenat
    • Nov 2015
    • 22
    • Argentina
    Re: Can't Melt Solder on Power Board
    A small tip don´t have enough power to heat a big surface . Do you have a heat gun ? if so you must heat the whole area before using the iron . Then put some new lead solder to make it easier .
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Dont solder with a heatgun , you might destroy other parts.
      You need a good solder iron. 85W solder iron is more then enough to desolder capacitors.
      You probably need a bigger tip otherwise the board will take all the heat and the solder wont melt....
      • ivtec
        • Dec 2008
        • 1967
        I'd suggest, first add more solder to cap legs then use sucker pump .
        • arenat
          • Nov 2015
          • 22
          • Argentina
          heat the whole area BEFORE using the iron
          • petehall347
            • Jan 2015
            • 4427
            try adding flux . what caps are they ? like are they through hole ?
            fit larger tip . 2 or 3mm i think .
            • barryra
              • Aug 2013
              • 107
              I got the solder to melt.... I needed to reset the Hako unit & was fine. Thanks for the replies.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • liquidzorch
                862D+ solder station iron out of control when fan on
                by liquidzorch
                Hello.
                I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                06-09-2022, 08:49 PM
