Bravia kdl 55ex640 vertical green lines
  • paulstef
    • Dec 2013
    • 724
    This TV has vertical green lines whereever there is supposed to be black.
    There is also some smearing effect.
    I'd say it looks like a panel failure but maybe somebody has some good news for me?
    • 12207
    • U.S.
    Re: Bravia kdl 55ex640 vertical green lines
    Can you get a menu up?
    • budwich
      • Jul 2015
      • 3097
      i kind of doubt that its a panel failure based on the limited photo.
      • paulstef
        • Dec 2013
        • 724
        yes, it also shows on menu. whenever it should be black I suppose... In the attached pic the little green dots are not supposed to be there....
        The smearing effect makes me think this cannot be caused by TCon or others..
        On TCON my VGMA voltages are good (in sequence).
        I had maybe 6 Sonys on my table in 3 years or so and all of them were unrepairable...
        • maxvalutech
          • 804
          • australia
          Its hard to interpret from that pic as to where on screen the problem is showing. Its certainly unusual and doesn't look exactly vertical but more like a scan pattern left to right down the screen to the very definite cut off point.
          • paulstef
            • Dec 2013
            • 724
            ok here is another pic.
            The moire is due to my cellphone camera. It is vertical green lines.
            The appear anywhere where it's supposed to be black. Like when I turn on the TV for a second while there is no picture yet the whole screen looks like this.
            • maxvalutech
              • 804
              • australia
              I'm with budwich in thought on this and would be trying another tcon if cheap enough and the ones I have purchased mainly China sellers $12 -$30 aud. If still no go its worth it for the learning experience?
              • paulstef
                • Dec 2013
                • 724
                ok, thanks guys, I'll see if I find one...
                  • 12207
                  • U.S.
                  http://www.shopjimmy.com/samsung-lj9...-con-board.htm There's a good pic. of the tcon, wonder if it can be fixed if it is indeed the culprit?
                    • 12207
                    • U.S.
                    https://www.aliexpress.com/item/WDL-...792789753.html Not sure but this ad claims this tcon will work for those four different screen sizes, wonder if it's accurate, if it is, it will be a little easier to find one.
                      • 12207
                      • U.S.
                      http://www.ustvparts.com/apps/websto...utf8=%E2%9C%93 If you can confirm the info. in the alieexpress ad to be true, then there's two there, think one says 46x640 and one says 46x645, 38 bucks and 34 bucks, maybe call them and ask if they know if it will work in your model and panel number and maybe check sticker numbers.
                      • budwich
                        • Jul 2015
                        • 3097
                        you could do yourself a BIG favor if you input a KNOWN test pattern... like smpte color bars / test chart. Then post a picture, you will get a better "guess" as to the issue... although there is little chance that a panel issue will cause such a "uniform disturbance" on black areas across the panel without other things obviously happening.
                        • paulstef
                          • Dec 2013
                          • 724
                          ok, thanks again for your input, I'll check the test pattern as well
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            i would get down and dirty with it and heat up tcon board then freeze it and see what happens
                            • maxvalutech
                              • 804
                              • australia
                              I'm somewhat intrigued that the logo shadow seems unaffected with the green dots seemingly under it. What affects the LCD ? Well if on all inputs then first thought is tcon with service menu settings next in line and that leads to test pattern checks as budwich has suggested before tcon purchase.
                              • paulstef
                                • Dec 2013
                                • 724
                                I was so sure to have a panel fault that I didn't even think of heating/cooling the boards.
                                Finally it's an area under a processor on the mainboard that is sensitive to heat/cold but not to bending/pushing... Sometimes the picture is ok sometimes not
                                Gave it a hot air solder station sweep but didn't work. Now I first have to ask the TVs owner if he wants to take the risk attempting to repair the board. Probably an BGA chip (it's under a shield, not visible) or some via or some ceramic capacitor etc.
                                This gives it some closure at least and I know it's not the panel. Learned something
                                Thanks again to all
                                • 265chemic
                                  Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
                                  by 265chemic
                                  Hi All,
                                  I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
                                  My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
                                  Below are some photos...
                                  03-23-2022, 04:53 PM
                                • Falki
                                  Colorful LCD Vertical Lines on Samsung ue55es8090
                                  by Falki
                                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                                  A similar issue has been posted as well but also with no actual response ...
                                  Yesterday, 04:19 AM
                                • visionbluedemon
                                  Help. Sony kd-65x85dj vertical lines
                                  by visionbluedemon
                                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                  tried blocking LC lines too, but same results
                                  is it lcd panel issue or tcon board issue?...
                                  07-25-2025, 04:56 AM
                                • arctor
                                  samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                  by arctor
                                  hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                  04-26-2025, 05:22 AM
                                • gpo23
                                  Sony KDL-40V3000 - Vertical lines
                                  by gpo23
                                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                  With the new t-con the color are good but there are vertical lines on all the screen :
                                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                  Is there a way to fix the vertical lines on the new t-con ?
                                  Thank you for your help
                                  gpo23...
                                  10-04-2023, 09:11 AM
