Scored this along with a 60PV250 from people who advised "picture stuck on little one sound but no picture on the big one". So yes this one is stuck at the LG startup screen and won't go any further. Does switch on/off with remote and set controls, receives commands but doesn't react - so I suspect eeprom (nand flash on this I think). Have been able to download new firmware to USB but can't get it running to upload. Have tried freeze spray, menu menu on set and rc but no results. Anyone have any knowledge how to get beyond the splash or kick start this set??
LG 42LE7500 stuck at splash screen
Tags: None
Re: LG 42LE7500 stuck at splash screen
A couple of days ago on this site someone successfully unbricked their set with instructions from
https://wiki.samygo.tv/index.php/UnB...y_EEPROM_ResetWilling to help but I'm no expert. -
Probably needs a reflow.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
One guy did a preheated oven at 385 fahrenheit for 10 minutes but who knows how long this type reflow will last.Last edited by nomoresonys; 04-29-2018, 07:22 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
OK and thanks for advice. Yes the boards in these look weak and subject to heat flexing I would think. Obvious main board problem so went over it all with heat and then gave it a try. The set fired up and I was able to tune it in, check and reset all settings, and give it a good run. When turned off to standby and then restarted backlights did not come on, however this morning it started normally so took the opportunity to update software which took as described. Now for a few days testing and here's hoping.Comment
https://wiki.samygo.tv/index.php/UnB...y_EEPROM_ResetComment
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by Yehuda170original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
with original broken screen i can see in device manager touch screen in human interfaces
but with the new screen it's not showing in device manager
is it lenovo blocking it? is it driver missing?
I²C is a headache -
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! -
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... - Loading...
