smps ic
  • B33M
    • Jun 2013
    • 8
    • Us
    smps ic
    Im looking for a suitable replacement smps ic for this
    https://photos.app.goo.gl/tZvnFnU6iWpYAXH46
    Would this work?
    https://www.semicon.sanken-ele.co.jp/ctrl/en/product/detail/STR-W6053S/
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: smps ic
    The part number is Q0465R and is available on ebay
    I would also check all the components around that IC before fitting the replacement.
    • Woodsworth
      PS3 CECHC03 60GB YLOD Troubleshooting
      by Woodsworth
      I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
      START
      Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
      03-19-2024, 07:58 AM
    • dkneyle
      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
      by dkneyle
      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
      02-01-2022, 02:08 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • abhishekkumar1902
      Huntkey HK340-72FP SMPS shut on load above 2 amps
      by abhishekkumar1902
      I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
      I have checked the following:
      1. All output caps are OK, and all output rails read correct voltages at no load
      2. All output diodes are OK
      3. NTC is ok
      4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
      5. No short in main switching MOSFET
      6. All other components...
      12-18-2022, 09:52 AM
    • madan1
      Mackie Th15 SMPS low Vout
      by madan1
      I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
      It is basically a smps with amp and some dsp.
      The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
      Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
      By the way, the ferrite core of L10 is broken,...
      02-16-2025, 04:15 PM
