IGBT Transistors FGPF4633, 30F126, 45F122 replacements
  • goldbird78
    • Feb 2018
    • 188
    • canada
    Is there a IGBT that would be suitable replacement for all 3 ? And if there is can you just replace the bad transistor/s or would you have to replace all as a set to match ? Thanks
  • mikkele86
    Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
    by mikkele86
    hello.
    I have two power amplifiers, both having their IGBT blown on the PSU.
    The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
    I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
    I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
    So I though i missed a capacitor or diode. I removed...
    01-06-2024, 06:45 AM
  • TURSTY
    Replacement IGBT's for LG TV reading weird
    by TURSTY
    Hi guys,
    I have a LG Plasma that went bang one night.
    Long story short, I took it to a "professional" shop to repair the YSUS board that was shorted and they did a half ass job.
    I'm a long way down the path of teaching myself component level repair, but not 100% confident in everything yet, hence what might be a basic question.
    The repair shop replaced 3 transistors on one of the two heat sinks and fixed one short, but the second set of transistors on the second sink still had a short.
    So I removed this sink...
    08-01-2023, 07:38 PM
  • slybunda
    Gemcon capacitor replacements?
    by slybunda
    taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
    there are 2 caps which im looking to get replacements for.
    Branded as Gemcon
    single 100uf 16v 6.5mm x 11.5mm
    single 100uf 50v 8mm x 11.5mm
    lead spacing is around 3mm
    there is space for 16mm tall caps
    rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
    the caps have...
    02-05-2024, 03:36 PM
  • sarry86
    Need help with IGBT 1450va ups/inverter
    by sarry86
    Hello everyone, I have this ups/inverter IGBT 1450VA which was working great until it started showing short circuit on a small lcd screen, I opened it up and started troubleshooting it and indeed I found some fault transistors, I decided to get rid of all of the transistors next to the shorted ones and it worked for some minutes without a problem, but then I heard a relay tripping off, and now it is showing that 2 batteries connected in series have no power at all, and if i disconnect the 24dc in then the battery are showing they are full (28vdc) with another inverter, they are working great no...
    09-24-2023, 06:17 AM
  • burom
    Xbox 360 Xenon Modern Capacitor Replacements
    by burom
    I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
    I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
    06-07-2024, 05:10 PM
