Bypass disable SOS - Panasonic
  • itelite
    • Aug 2016
    • 124
    I have a purely evil TH-50PX60U that is giving 6 blinks.
    I have already replaced SC and SS. I have tried removing SD and SU one by one with no change. Just 6 blinks.
    Occasionally the tv will turn on and run for about 10 minutes before shutting down with 6 blinks. I have no explanation for this.
    I would love to bypass SOS6 and hopefully stop the shutdown. Even if something explodes, at least it will give an indication of where the problem is.
    The SOS6 line will go to 2.7v before the tv shuts down and then it of course goes to zero.
    I have cut the SOS6 line (8 blinks), tried grounding (8 blinks), tried feeding 2.7v, 3.3v , and 5v into it. All of these get 6 blinks.
    Can someone explain how these SOS lines work, and if it is possible to fake the signal required to tell everything to keep running.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Bypass disable SOS - Panasonic
    You may be able to fake the signal by monitoring pin 3 of Ic 9003 on D board as the TV is working and keep watching the voltage when the tv shuts down I believe there should be 5v.
    If TV shuts down and voltage goes low on that pin you may be able to inject 5 V into that can to keep it alive. There is a reason for this to be happening and it may be caused by a shorted COF on the C buffer
    • itelite
      • Aug 2016
      • 124
      appreciate it. i will give a try.
      for what it's worth, when it is running, there is no visible indication anything being wrong.
      I also unplugged the FFC cables from the d board as a troubleshooting step, with no change from the 6 blinks.
      • freakaftr8
        • Oct 2012
        • 3743
        Ok. The D board sends the 5v through the SC to the C buffers and back to the D board. Stupid but that's how it works.
          SOS6 is generated by the VMID / ER voltage balance.
          I would check the VMID voltage on the poly caps in the energy recovery circuit
          Follow the schematic and it'll show you where SOS6 is generated...
          • itelite
            • Aug 2016
            • 124
            Excellent. Will check those caps, as well as get some voltage measurements form the circuit.
            I spent most of yesterday in the schematic to no avail ha.
            For the record, issue is exactly the same across 2 different SC boards, and 2 different SS boards. So that is why i haven't dug too deep into the circuits on those boards.
            I suppose one of the main things i am wondering is what exactly does a valid SOS signal look like? This is just going high(?) 2.7v until the set powers off, but when disconnected or held low a then get a 8 blink code. That is to say, when looking on an a scope i dont see any discernible signaling pattern, but i dont know if i really should.
            • R_J
              • Jun 2012
              • 9535
              If you have the same problem with two different SC & SS boards, It could be the D board that is faulty, There is a zener diode (D9019) that could be intermitint, or C9051 Try lifting them and see if the fault is still there.
              Check the voltage on R9110
              • itelite
                • Aug 2016
                • 124
                Wondering if the schematic i have is not correct. Board is TNPA3820 AC 1 d
                The numbers on the board do not match the schematic numbers at all. For instance IC9003 is shown as existing on the schematic. Where as i have things like IC300 and IC400 on this board.
                Matches perfect to the board layout of the D board in the board layout image in the service manual.
                • R_J
                  • Jun 2012
                  • 9535
                  I believe it is ic003 on the board, drop the `9' The zener diode D9019 would be D019
                  • itelite
                    • Aug 2016
                    • 124
                    Yes, dropping the 9 makes sense.
                    lifting the ZD and cap made no difference. Capacitor is not shorted. r9110 reads 100 ohm as expected. R9172 read 39k as expected
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • CrewmanRedShirt
                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                      by CrewmanRedShirt
                      Hello all,
                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                      07-13-2024, 11:02 AM
