Samsung LN40B550K1F no power
  • PeteTait
    Newer Member
    • Jan 2014
    • 41
    I acquired this tv with out any knowledge of what the problem was. I plugged in and had no power. Opened it up checked the caps and fuses. Caps looked good. First fuse closes to power plug was good. Second fuse was blown. I swapped it and it plugged the set in and it immediately blew. Where do i look next?? attached is a picture of the board with the fuse that is blown circled in red.
  • maxvalutech
    • 804
    • australia
    Re: Samsung LN40B550K1F no power
    I'll supply this circuit diagram and hopefully the real experts will chime in for you.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Check these parts first. I like the Rod Farva icon. Only 9 days till supertroopers 2!
      • PeteTait
        Newer Member
        • Jan 2014
        • 41
        Well i am going to print the circuit diagram and start circling the part numbers that were recommended to check. Then find them on the board and check.
        • freakaftr8
          • Oct 2012
          • 3743
          Most likely QP801 and 802S shorted. Shoddy soldering casused this most likely. Thanks ROHS lead free solder!
            • 12143
            • U.S.
            Check your diodes and transistors too, see if any are bad. Testing video https://www.youtube.com/watch?v=i4jTHhXuKLA
            • neilc6
              • Nov 2015
              • 1550
              +1 for shorted transistors. See my post here https://www.badcaps.net/forum/showthread.php?t=67743
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • hill01
                Samsung UE75MU7009TXZG Endless Power Cycle
                by hill01
                Hi everyone and thanks in advance for any help I might get here
                My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                Since a few days, the TV won't turn...
                11-17-2021, 02:52 PM
