E701i-A3
  • jstiene
    • Feb 2013
    • 148
    E701i-A3
    Hello.
    I was given a Vizio E701i-A3 and when I turn it on the screen flickers. Video and sound seem ok. Before I open it up and troublshoot, I was wondering if this is a bad screen issue or a board failure. Has anyone had the same issue with this model?
    any information would be much appreciated. Thanks!
    Joe
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8213
    Re: E701i-A3
    Depends on what you understand on 'screen flicker'. Maybe tab bonds, clean and reseat all the ribbon cables...
    Upload some pictures or a video so we can see something... your description is just way to vague. Does the whole screen flicker, or is it just a part of the screen. Does the backlight flicker or is it the actual picture?
    • jstiene
      • Feb 2013
      • 148
      Re: E701i-A3
      Actually I was a little fast in my explanation. What happens when I turn on the TV is that it will start to flicker (the backlight). Picture is fine to start. Then after 5 minutes I lose all video and sound continues to work fine. Is this a known problem with the screen or more likely a TCON problem?
      Any help would be appreciated.
      • freakaftr8
        • Oct 2012
        • 3743
        Re: E701i-A3
        Shine a flashlight into the screen and see if your video is still working. I'm assuming that when you say the picture goes out the back lights go out as well?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8213
          Re: E701i-A3
          Your explanation is still a little vague. By loosing all video you mean the back lights go out? Turn the back lights waay down and see if it will quit flickering and stay on longer.
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • cloudy
            HELP - Contrast/brightness issue with subtitles on screen
            by cloudy
            Hi everybody
            Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
            Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
            Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
            It occours both on ubuntu and windows...
            01-01-2023, 05:12 PM
          • ScHAmPi
            Samsung UE48JU7000 screen issue after backlight replacement
            by ScHAmPi
            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
            07-15-2024, 05:41 AM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
