Samsung Plasma PN42C450B1D - IGBT keeps shorting
  • caphair
    • Nov 2011
    • 1249
    This set originally had two shorted IGBTs on the Y-Sus board.
    I ordered some replacements from China and installed. But upon plugging power cord in one of them keeps shorting from collector to emitter and set won't power on just hear a couple relay clicks and goes back into standby.
    I confirm it's only the Y-Sus board by unplugging it and set comes on (with no picture)
    Bad parts or something else going on?
    Here's a pdf I found of the IGBTs
    https://www.scribd.com/document/231709293/RJH30E2
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung Plasma PN42C450B1D - IGBT keeps shorting
    First off. Have you done resistance checks after removing the shorted MOSFETs? D4006 looks blown and I bet your gat e drive IC at U4006 is shortred as well. This will cause your new MOSFETs to not stand a chance
    • caphair
      • Nov 2011
      • 1249
      It's not blown I checked. There's a red paint mark on it that makes it look blown in the pic.
      I've done resistance measurements from ground to the collector/emitter pads with the mosfet off and don't get any alarming readings
      • diif
        • Feb 2014
        • 6978
        • England
        I had the identical board and bought some RJH30E2 from China. The left one shorted upon applying power. There was another thread on here with the same and suggested they were fakes.
        I bought a second lot of RJH30E2, installed and they were fine.
        • caphair
          • Nov 2011
          • 1249
          So only one would short everytime? I wonder why only one would short and not the other if they're the same type?
          • diif
            • Feb 2014
            • 6978
            • England
            The left one (looking at your photo) definitely failed, the right one might have but I don't remember. I did nothing extra apart from order a second lot, which worked fine.
            Perhaps they are factory seconds and not quite up to spec ?
            • chrismurphy
              • May 2014
              • 251
              • australia
              check the gate drive resistors , if you have an open this will destroy the igbt
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4467
                • Italy - Milan
                have you checked el.caps on the power board especially on vsus?
                • mikkele86
                  Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                  by mikkele86
                  hello.
                  I have two power amplifiers, both having their IGBT blown on the PSU.
                  The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                  I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                  I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                  So I though i missed a capacitor or diode. I removed...
                  01-06-2024, 06:45 AM
                • Biruslapio
                  Plasma Y board IGBT equivalency question
                  by Biruslapio
                  I have two TVs here with both Y-SUS failures, one LG and one Samsung.
                  The Samsung's Y-main shorted one FGD4536 and one RJP63K2(there are two in parallel)
                  I have the FGD but I only have one RJP63F3, which is different from the K2, so, can two 30J124 be put in place of two RJP63K2? are they equivalent?
                  Also for the LG two 30F131 shorted, I have some FGD4536 (the same that are used on the samsung), can they be also be a substitute without issues?
                  RJP63F3 and K2 are 630V 30A IGBTs, but their rise/fall time and other internal variants differ.
                  04-06-2023, 08:09 AM
                • theflyingsquirrel
                  Chromebook USB-C no longer recognized USB devices after shorting
                  by theflyingsquirrel
                  I have a Samsung chromebook Pro and one of the USB-C port have something inside and was shorting. The particular thing look like a loose soldering debris. It was at a bit off middle so I think it was shorting the vbus and data pin. I ended up desoldering the whole usbc port and removed it. Upon removoing the usbc port, the chromebook boot again. I can charge with the remaining usbc port (now I found out that when I charge with higher power charger, it does not work), but I cannot get it to recognize any USB stick I plug in. May be the handshake is gone? In the pictures, you can still see the USBC...
                  02-25-2025, 09:23 AM
                  Hypertherm Plasma Chopper IGBT Module failure successful repair
                  by sam_sam_sam
                  I have several chopper units that need to be repaired but just repaired one of them to see if it could be done successfully which they can be repaired
                  The company that makes the IGBT module have discontinued this part as 5/30/2020 which our company has bought 12 IGBT modules which will allow me to repair 6 chopper units ( one note there is no direct replacement availability )
                  I am buying these modules directly from the manufacturer
                  But there is a 8 week lead time
                  Now you can find on EBay for half the price but I have a feeling that might be fake...
                  06-07-2020, 11:08 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
