Samsung BN44-00214A Power Supply for LN32A450C1DXZA
  • kenmoe
    • Mar 2018
    • 23
    Re: Samsung BN44-00214A Power Supply for LN32A450C1DXZA
    that voltage is when the resistor is in place which means it should be powered on but it's not
    • nomoresonys
      • 12276
      • U.S.
      #42
      ok, forgot you jumpered it.
      • nomoresonys
        • 12276
        • U.S.
        #43
        Ok, til you get 380 at the filter cap, the powersupply will not work right.
        • nomoresonys
          • 12276
          • U.S.
          #44
          http://www.shopjimmy.com/samsung-bn4...upply-unit.htm pic. so it's right on this page.
          • nomoresonys
            • 12276
            • U.S.
            #45
            Look closely at CM808, any bulging of the sides or leaking? take a good look at CP801 too.
            • nomoresonys
              • 12276
              • U.S.
              #46
              https://www.youtube.com/watch?v=ASMOVbOZac0 Well hell just do this then, couldn't hurt.
                OK, lets verify if the PFC diode DP801 is OK or not by checking the RESISTANCE in both direction of that diode.
                • kenmoe
                  • Mar 2018
                  • 23
                  Removed one leg of DP801 and checked resistances.
                  Black lead to Cathode - 1.5M ohm then slowly climbed
                  reverse - open line
                    Well, I was hoping that it will be just the bad diode for the PFC, so now we need to dig deeper into the circuit. You will need to find out if the PFC ICP801S is getting the switched Voltage at VCC at pin 8 for it to run or not.
                    You will have to flip the board over while making the live Voltage test in the hot deadly side of the circuit, the GND ref. point for your meter will be the negative leg of the main filter cap.
                    See the diagram for details. The IC is very small SMD so make sure you do not let the probe slipped on you and do not touch anything with your body or your hands.
                    • kenmoe
                      • Mar 2018
                      • 23
                      I am getting a steady 9v at VCC pin 8 on ICP801S
                        9VDC is too low, the turn on Voltage is 12.5V (Typ.) so you need to check the Voltage between:
                        GND and the Collector of QB802.
                        GND and Base of QB802.
                        Based on the schematic, the VCC pin should have around 15VDC.
                        • kenmoe
                          • Mar 2018
                          • 23
                          Checked the voltages of QB802:
                          GND and Collector -40.2v
                          GND and Base steady -54.6v
                          Should this voltage be negative voltage
                            That looks like you are using the wrong GND, you are working in the HOT side so the negative leg of the main filter cap is your GND ref, same way you use for making the measurement of the VCC pin.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                              09-07-2024, 05:50 AM
                            • cheeky2
                              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                              by cheeky2
                              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                              06-15-2025, 05:12 AM
                              03-31-2024, 02:12 PM
                            • Cookybaby
                              Samsung UN60ES6500FXZA Power Supply Issue
                              by Cookybaby
                              Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                              I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                              Make: Samsung
                              Model: UN60ES6500FXZA
                              Power Supply P/N: BN44-00525A
                              Symptoms: The TV was...
                              08-20-2023, 12:26 PM
