Samsung BN44-00214A Power Supply for LN32A450C1DXZA
  • kenmoe
    • Mar 2018
    • 23
    Re: Samsung BN44-00214A Power Supply for LN32A450C1DXZA
    I rechecked all the readings and i am getting 3.5v on the pwr on pin for a second or two, then it cuts out for a second or two. Repeating over and over
    • kenmoe
      • Mar 2018
      • 23
      No change in led when pw button pressed and no startup chime
        BTW, PS-ON pin is pin 1 of the CNM802 that goes to the main board, that is the pin we need to verify if we have the PS-ON to turn on the power supply or not. Right now we are trying to see what Voltages you have between the power supply and the main board that is why we need to check CNM802.
        CNM801 is for the inverter board which we are not dealing with it at this point.
          At this point to make it less confused, you need to report all the Voltages of the connector CNM802 of that power supply board.
            Are we talking about pin 1 (labeled as 'PS') on the connector CNM802? If that is the case then you have something bad going on in your main board that causes PS-ON to cycle on and off which will male 12v/24V circuit to go on and off, same for the PFC Booster circuit will not be on steadily either..
            • kenmoe
              • Mar 2018
              • 23
              CNM802
              pin 1 constant on and off 3.5v
              pin 3 steady 5.2 V
              • kenmoe
                • Mar 2018
                • 23
                I guess I should mention that one of the last times the tv started up, it turned on by itself when plugged into the wall. I was able to turn it on and back off with the power button at that point. As of right now, the tv will not turn on even when left unplugged overnight like previous
                • kenmoe
                  • Mar 2018
                  • 23
                  yes correct. But the PS still puts out these low voltages when disconnected from the mainboard, and not getting a signal to turn on.
                    CNM802
                    pin 3 steady 5.2 V
                    OK, so you main board not sending steady on control signal to make the PFC Booster circuit and the swithed 12V/24/ to be on steadily.
                    Can we see the pictures of your main board and the pictures of the whole backside of the TV showing all the boards?
                      BTW, you can also test the power supply board by itself by soldering in the 1K resistor between pin 1 and pin 3 of CNM802, just make sure to disconnect the cable to the main board first.
                      • kenmoe
                        • Mar 2018
                        • 23
                          You do have main board problem, you can try heating the main board for 2~3 minutes then power the TV to see what will happen, you can also try cooling the board with canned air duster using it upside down to get the coolant out.
                          • kenmoe
                            • Mar 2018
                            • 23
                            I will try the resistor and check back with the results
                              Same problem as yours.
                              https://www.badcaps.net/forum/showth...ht=LN32A450%2A
                              • kenmoe
                                • Mar 2018
                                • 23
                                I also thought it could be the mainboard until I seen low output voltages when the mainboard was disconnected and no resistor to tell it to turn on
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #36
                                  https://www.ebay.com/itm/Samsung-LN3...4383.l4275.c10
                                  19.66 free shipping.
                                  • kenmoe
                                    • Mar 2018
                                    • 23
                                    using a resistor to jump pins 1 and 3 did not result in any other results. I'm still getting the same output voltages
                                      OK, so you have a the power supply problem also.
                                      Wit that resistor still in place, you will need to find out if you do have the 380VDC boosted Voltage or not by measuring the DC V between the two legs of the main filter cap.
                                      • kenmoe
                                        • Mar 2018
                                        • 23
                                        By main filter cap you mean CP803, then I get 160v when measuring across the two leads of the cap
                                        • nomoresonys
                                          • 12276
                                          • U.S.
                                          #40
                                          That should be the reading in standby, now power tv on and check, should be around 380, if it is that verifies your PFC is ok.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            09-07-2024, 05:50 AM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                            03-31-2024, 02:12 PM
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
