Vestel 17IPS20 circuit diagram
  • Helari
    • Mar 2018
    • 5
    • Estonia
    Hi!
    I would appreciate if anyone could provide me with Vestel 17IPS20 power board circuit diagram for Hitachi 55HZT66 LED TV. Board product code 23182849-27473304.
    Thank you in advance!
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Vestel 17IPS20 circuit diagram
    Hi if you use the search function of the forum and put in 17ips20 it will bring up loads of threads regarding this psu you may find a schematic that matches your psu also what is the issue with your tv/psu? .
    • Helari
      • Mar 2018
      • 5
      • Estonia
      R2, J15 and a trace blown. Water caused short circuit.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        R2 looks like a 10R this is the only schematic i have at the minute
        • Helari
          • Mar 2018
          • 5
          • Estonia
          Did not manage to repair the board - bought a new (used, same code) one from UK. Now TV starts up and works, but shuts down (stand-by mode) after about every 2 mins (dimmes screen before shut down, same after restart). Does it need to be reset somehow to work normally? Any ideas?
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • massimomax
            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
            by massimomax
            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
            spero che qualcuno può averlo per riprogrammare eprom. grazie
            Post in English !!!
            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
            02-28-2025, 07:27 AM
          • klebendes_etwas
            Search for: QSC K10.2 Circuit Diagram & Component Layout Overview
            by klebendes_etwas
            Hello everyone! :-)
            An acquaintance of mine works as a DJ in his spare time and brought me a defective QSC active loudspeaker (Model: K10.2) for repair.
            Error description: The device could not be switched on (after he lent it to another DJ).
            A visual inspection revealed an obviously blown fuse (F41) and a cracked thermistor (R41) on the mains filter board. A closer look at the amplifier board revealed two defective power MOSFETS (Q13, Q14) and other defective components on the +12VLOW rail.
            After replacing all the obviously defective components, the...
            09-21-2024, 04:00 PM
          • Thomas Dunlap
            Request Dell G16 7630 LA-m536p circuit diagram and board view
            by Thomas Dunlap
            Hello looking for a circuit diagram and board view for la-m536p. Thanks in advance
            Included the specific model detail below:
            Reg model: p122f
            Model: Dell G16 7630
            ST: h2tm044
            08-25-2025, 03:04 PM
          • MMCNet
            I need Asus C2131A circuit diagram
            by MMCNet
            I need Asus C2131A circuit diagram, I hope to receive everyone's help. Thank you.
            07-28-2025, 08:46 AM
