LG 50PC5D-UC.....Score!
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    A couple days ago I was cruising Craigslist and found this LG 50PC5D-UC for free pick-up. Got the back off it today and found one fuse blown on the AC side of the power board. I didn't find anything shorted or any obvious problems so I replaced the fuse.....and it WORKS! The fuse I put in is a temp, undersized at 125V 4A as opposed to the 250V 4A originally in the socket
    With the things I learned here, especially from @Freakaftr8 I was able to troubleshoot this with a fair level of confidence and resulted in a bit of a "morale boost"!
    The only issue I see with it are red speckles towards the bottom of the screen that increase in coverage with images towards red in color. It's only at the bottom fifth of the screen or so, but the picture is still really, really nice!
    Another remarkable thing....this was like the cleanest TV inside that I've ever seen....bar none....and I see no evidence the back's been off anytime in the recent past. The remote is squeaky clean too!
    So does anyone have an opinion on my red shooting stars? Any opinion on it's value? I know it's not likely a high value unit due to age but that isn't the point....it's more about the cool factor!
    They call me......."threadkiller"
    Re: LG 50PC5D-UC.....Score!
    Cool fix.
    It's not worth much.
    The sparklies are a common issue on LG plasmas. If it's an old unit, and it's only red sparklies, you might be able to get somewhere tweaking the set_up and set_dn, as well as Vy voltages. Note original settings with marker pen before doing this.
    However you will almost certainly need to fix the set properly which involves downloading a software update onto the control board.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Originally posted by tom66
      Cool fix.
      Right on! Can I download this on to a thumb drive and use that to download it to the set?
      I had a look at the service menu. It has 21,588 hours on it....not even halfway to half-dim time!
        No, you can't unfortunately, you need a specialised jig.
        I'd check on a full white pattern for burn in...that's more of a concern than phosphor half life.
        • NYKing
          • 17
          Yeah, 90pound 720p plasmas are not worth the trouble nowadays. A friend owned this exact model and could not sell it, even for $20 in perfect working/cosmetic condition so he gave it away to a neighbor.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            This is good to know. In my area folks don't have a lot of disposable income so older TV's seem to still get some interest here.
            It's still in my living room going strong and the picture looks great!
            • nomoresonys
              • 12274
              • U.S.
              That's 900 days or almost 3 years running and still going strong, that's a good tv.
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                It's a February 2007 model....that would make it about 6600 days old, and it has 21,652 hours UTT. I'm pretty sure it has a glass front screen too.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  This is the final update on this TV. After 150 hours of testing in my living room and no further service needed this TV just sold for $175.00!
                  You all have been really kind and good to share your knowledge with me. The sale of this TV has led to the recovery of my entire investment in gas and cash invested in 16 TV's. I'm not in profit territory yet, but I'm even, and that's not bad to start! Thanks to all of you.
                  Now I have free TV's to learn on, and this is exactly what I hoped for. I may not get any more for now unless I know I have parts or it's super nice condition, or free.
                  As soon as I get time I'm going to post my parts TV's and board numbers on the site here. If you've taken time to help me through to a solution and I can help you with some parts you need I hope you will let me know.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Nice job!
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      Thanks, and thank you for all your help freakaftr8! Maybe one of these days I'll have/get a board with your name on it?
                      • chrismurphy
                        • May 2014
                        • 251
                        • australia
                        A 4 amp fuse is 4 amps regardless of voltage
                          The voltage rating is still important, though. It indicates the highest voltage the fuse can safely interrupt.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            V=I over R. I think.. I may be wrong.. But 4amp at 250v 8 amp at 120v. But these supplies have a dual sensing. I believe if the power supply is 120-220vAC.
                              Nothing to do with that.
                              It's just to do with arcing in the fuse.
                              If the fuse never blows, 4A 125V, 4A 250V heck 4A 32V are all equivalent.
                              And if the source has relatively high impedance (can supply little current), then those fuses are also equivalent even if the fuse blows.
                              The problem comes when the supply is low impedance - such as mains power - and can supply a lot of current. Short circuit current for domestic mains socket at 230V is well over 500A if your house is wired well. Slightly less in USA. You want the fuse to be able to interrupt that safely. The higher voltage rating of the fuse indicates the typical supply voltage that the fuse can safely interrupt without the arc reigniting and continuing to conduct after the failure...which could cause a lot more damage elsewhere.
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                Well just so everyone knows I pulled a 250V 4A fuse out of another TV and installed it about 1/4 of the way through testing. The 125V went in because was in the next room and was the same amp rating.
                                • vulubalulu
                                  Dell U2718Q, horizontal lines. second opinion welcome
                                  by vulubalulu
                                  I have never seen an issue such as this one. horizontal lines across the monitor in a consistent manner. I am really interested to get to the bottom of this and I'd value any input from the community.
                                  There are three separate PCB parts attached to each other. They function as SMPS, backlight driver and main board.
                                  I checked the all three blue PCBs: SMPS outputs 19V, PWM controller + mosfets without anomalies, main board has 3V, 5V, 10.5V and 19V present. Crystals output the right clockspeed. This is to be expected as the monitor turns on.
                                  I haven't explored at the green PCB (TCON...
                                  08-14-2024, 03:08 PM
                                • unnu
                                  please tell me your opinion on this situation
                                  by unnu
                                  i was a proud owner of a new lenovo y560 laptop
                                  for me it was a very new experience to use a laptop . i had used only desktop PC many times. i enjoyed playing games on my laptop very much. This pleasure lasted only till the day there was a electric power cut followed by a power surge at my home and while i was playing a game (crysis 2) . when the power cut happened the laptop Operating System went automatically to power saving mode...so the heatsink cooling fan stopped spinning and then ( a few seconds later ) as soon as the electric supply resumed and power surge happened the laptop shifted...
                                  12-29-2020, 08:44 AM
                                • peku
                                  HP Omen 17-w104no dead PCH? Second opinion
                                  by peku
                                  First some laptop info:
                                  Model: HP Omen 17-w104no
                                  Motherboard: Quanta G38D
                                  CPU: Core i7 I7-6700HQ (I think?)
                                  GPU: nVidia GTX 1070
                                  What happened: plugged in an old smartwatch for charging/syncing after years of no use, after a while computer just shut down, leaving a little white light at the power button. Pressing power after that, nothing happens. After opening up case and disconnecting/connecting battery, not even that white light appears, no light on the charging connector either.
                                  I've tried diagnosing with a multi-meter...
                                  01-25-2022, 07:47 AM
                                • Ancient1
                                  Toshiba 65S2650EV 65" TV What in your opinion the issue is ?
                                  by Ancient1
                                  Flickers at lower half (only? short vid. )
                                  Buyer drove 100km with it, after it goot a bump at the staircase.
                                  It was repaired "here" highly unusual and over 6 months long saga. ( I can give the link if you're interested )
                                  I used only VGA to check the display. He uses HDMI. ( told him to try VGA etc)
                                  Video : https://mega.nz/file/gdsUxAwR#HP2nHw...dUJfYXs2roKwgA
                                  12-14-2022, 10:03 AM
                                • jdbird613
                                  Audio Wire Connector Question/Opinion!?...
                                  by jdbird613
                                  So I've got this old "Program One" stereo receiver & equalizer, and the RCA jacks are pretty crummy from sitting idle for 20+ years, so I've ordered new jacks to replace the old ones...upon inspection, I see that the backside of the jacks are actually wrapped (pics) with the their specific wires...no sort of connectors present. I am taking a short cut and attaching 22-20 guage pull to seat terminals to the wires, and then connecting to backside of the RCA jacks as the pics show. They are are very snug fit, and I also plan to add solder for reinforcement. Can anyone offer me their...
                                  10-16-2019, 09:47 PM
