Hkl-480201b hkl-500201b hkl-550201b psb repair
  • GradientWizzard
    • Apr 2021
    • 6
    • United Kingdom
    #41
    Re: Hkl-480201b hkl-500201b hkl-550201b psb repair
    I'm guessing it's these 2 dull ones? https://i.ibb.co/MZBf9WZ/fuse.png
      • 12085
      • U.S.
      #42
      Yep.
      • GradientWizzard
        • Apr 2021
        • 6
        • United Kingdom
        #43
        OK, so done a test
        D10/D11 = 550
        D8/D9 = 895
        D13/D14 = 375 using a EEDM501B multi meter on the 2K ACV setting
          • 12085
          • U.S.
          #44
          Check some youtube videos on diode testing.
            Originally posted by GradientWizzard
            OK, so done a test
            D10/D11 = 550
            D8/D9 = 895
            Can you explain how you test the Diode on the 2K ACV setting?
            What setting of the meter did you use to test D8/9/10/11?
            Are you testing the diode with TV still plugged into the AC outlet?
            • GradientWizzard
              • Apr 2021
              • 6
              • United Kingdom
              #46
              I'm testing the diodes with a diode setting on a different meter they came back with a reading
              • GradientWizzard
                • Apr 2021
                • 6
                • United Kingdom
                #47
                So, I went ahead an purchased a new main board, turns out it's something further cause it's doing the same thing with a new board in the TV
                • djaywilly
                  • May 2021
                  • 7
                  I have a Haier 50" LE50d3505b television that is "dead." No image, no standby lights, no sound, no nothing. The power supply board is HKL-500201A.
                  I have tested diodes 10/11 using the "diode setting" on my multi-meter. I got .000 readings for both. For diodes 13/14, I got .177 for both readings.
                  Do you think diodes 10/11 are the issue and to replace them? If so....would these be the correct diodes to replace them with: https://www.ebay.com/itm/11376729897...QAAOSwDw9bLDvU
                  Thanks!
                  • djaywilly
                    • May 2021
                    • 7
                    pic
                    • nickgronk
                      • Apr 2021
                      • 32
                      Can confirm, D10 or D11. Had to take them both out of circuit to test though.
