Picture disappears after minutes Hitatchi 42PD3200
  • r-p
    • Feb 2013
    • 44
    • Netherlands
    Game monitor. Green snow/haze issue since getting it, but worked acceptable for few years. Then it got worse, tweaked voltages and works fine again and mounted it on a stand with wheels, but no sound so had to go through the issue of taking it off (2 person job), find that I forgot to hook up soundamplifier PCB and remount it (3 person job).
    But now it developed a new issue: it works fine, but after a few minutes, the screen goes black.
    I am pretty sure the on-screen volume control does not show either, but the sound still does work (so it does not go into some protection mode).
    Questions: when googling "plasma picture goes dark" it keeps mentioning shining with a torch to see if it still has some (dark) picture showing but without the back-light being ON, but plasma's don't have a back-light, correct?
    Other likely culprits (again, according to google) are capacitors on the power supplies, but Tom66 mentions in his repairthread that it is not likely a powersupply fault if you still have sound.
    He does mention "if you have sound and the TV will respond normally - then it's likely a Y-sustain or Z-sustain fault." But I am not sure what would cause it to function normally for a while before going into 'errormode', so I was hoping this would trigger some great ideas on where to look from you lot before having to take it down again...
    Thanks!
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Re: Picture disappears after minutes Hitatchi 42PD3200
    Is the time to picture off from cold consistent if so perhaps warm up triggers the problem. Also switch off just for a few seconds and back on and what happens?
    • r-p
      • Feb 2013
      • 44
      • Netherlands
      We decommissioned it because it displayed the failure-mode (=going black) on about 4 separate occasions on two different days.
      I just played on it for 15 minutes and it won't go black whereas before it would do so within 5 minutes.
      I will remove the temporary 26" in front of it and make it the main gaming monitor again. It will undoubtedly fail again once the kids go play on it in the not too distant future and I will answer your questions then. Thank you for now for taking an interest!
      BTW: when getting it because it was 'broken' years ago, Google told me Plasma's Always overheat so I added a load of fans on the internal heatsinks and they are always running. I just turned them off but still no failure mode.
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • JohnML1975
        Samsung UA50TU8000W no picture and no sound
        by JohnML1975
        Hello All
        have seen posts on this model in here but my problem sounded different so thought i would create a thread
        TV will not turn on
        There is no standby light
        When I press ON button for remote the red standby light does flash but no picture and no sound
        From the back of the TV I can see the red light on the back of the mother board
        Holding torch to the screen I cannot see a picture
        I removed the back cover
        Observing the boards I cannot see any damage
        I disconnected the main board from the power supply
        the back...
        08-30-2025, 09:40 PM
